09-07-2021 16:46
09-07-2021 16:46
Alta HR display fitbit.com/setup and not sync to my oppo phone. Not sure what's the reason. FYI this is a non-updateable version as per seller's claim.
09-07-2021 16:48
09-07-2021 16:48
Hi @zhr you can only download the app if you're running Android 8 or higher. here is the article about compatibility of the devices - click to read.
09-07-2021 18:00
09-07-2021 18:00
I have successfully downloaded the app as I have no issue on device/Android version. The app keep notifying me on latest software update but I have failed to do so after few attempts.
09-07-2021 19:20
09-07-2021 19:20
@zhr a firmware update goes to the actual device. click to learn more. A software update would be the app.
