08-15-2021
10:52
06:54
WilsonFitbit
08-15-2021
10:52
06:54
WilsonFitbit
problem with Alta HR and galaxy s21 synchronizing.
Best Answer08-16-2021 06:55
08-16-2021 06:55
Hello @Jimbo7599. Welcome to the community forums!
If you haven't done so, I'd recommend performing the suggested troubleshooting steps in this link: Why won't my Fitbit device sync?
On a side note, I've moved your post to the Alta & Alta HR board to keep our forums organized.
Hope this helps.
08-22-2021 20:36
08-22-2021 20:36
Alta HR with your phone. You mentioned you have tried different solution on your to address this issue, however I'm wondering if you have tried a restart on your tracker? It was released a new version of the Fitbit app recently, which I'm sure you've installed already, so I'm wondering how it goes so far?
If the issues still persists have you tried with a restart on your tracker? Perhaps this will do the trick to sync your tracker:
If you have the recent version of the Fitbit app: Android app version 2.66 is now available - 2/5 and the issues still is persists, try to log out from your Fitbit Dashboard and force quit the Fitbit, go to your app and log back in and try one ore time again.
See you later and hope you get back on track soon.
Best Answer08-22-2021 20:56
08-22-2021 20:56
@LeVuong there is a newer Android app out there and the link you gave does not work.
08-23-2021 12:07
08-23-2021 12:07
@LeVuong today the android app is at 3.31
