08-20-2018
		21:24
		20:08
		08-20-2018
		21:24
		20:08
I’ve read other posts. I too am not getting consistent readings of sleep stages. Yes the band is set properly on my wrist. Yes the HR is charged. Yes my heart rate tracks all night. Given everything I’ve read, could it be that Fitbit is having a software problem? Any thoughts? Any suggestions?
12-25-2018 21:04
                              12-25-2018 21:04
If the data wasnt collected, or the data collected was not enough to calculate sleep stages, then stages cant be suddenly created. It happens sometimes. I usually restart my tracker several times and see how it goes tonight, and it usually works fine.
Helen | Western Australia
08-21-2018 07:22
                                          Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              08-21-2018 07:22
Hi there @eawinnyc. Good to see you in the FItbit Community Forums! 🙂
I'm very sorry to hear that you're having problems with your sleep not being recorded correctly.
Now, I'd like to know if you're getting simplified sleep patterns instead of getting Sleep Stages or you will not get any sleep record at all. Also, how often is this happening?
Currently, our team is aware of users having difficulties getting their sleep stages recorded and it seems it's not something just about the tracker or something just about the app but about the whole process of calculating sleep stages but they're working on getting this resolved as soon as possible.
In the meantime, I'm not sure if you've already tried giving your Alta HR a restart. If not, you can easily do this by clipping your tracker to the charger and plugging the charger to a USB port on your computer or a wall charger. Then, Press the button on your charging cable three times within four seconds and your tracker should vibrate and show the Fitbit logo. This will make your tracker to reboot.
Hope this helps and if you need more help, let me know!
08-21-2018 14:46
08-21-2018 14:46
I’ve had my Fitbit Alta hr for about 6 weeks and it has also stopped tracking my sleep stages, only giving me simplified sleep data for the last 5 nights. I tried restarting which didn’t solve the problem. Nothing has changed with how I wear my Fitbit during sleep either and it is fully charged.
08-21-2018 17:18
08-21-2018 17:18
Thanks for the quick response.
I get the simplified sleep patterns. This happens a couple of days in a row. Then a night or two of sleep stages. And then back to simplified sleep patterns. This started at the beginning of July. Prior to July I had perfect recording of sleep stages every night.
I have tried the reset previously. I will try again. Thank you.
08-21-2018 19:50
08-21-2018 19:50
I am having the same problem. For the last 4 nights I have been receiving simplified sleep data. There has been no change to my sleeping position, environment or position of the band on my arm. I tried to restart my device yesterday & it made no difference.
Is there a software issue or update required?
It appears that a few of us are experiencing this issue...
08-22-2018 00:20
08-22-2018 00:20
Hi
This has started last night for me. Everything seems to be recording correctly, apart from sleep, all I get is the 'How did you sleep?' tile displayed.
08-28-2018 08:28
08-28-2018 08:28
A week later and my fitbit hr is still inconsistent night to night in showing sleep stages. More than a bit frustrating. Disappointed with this product.
09-02-2018 08:50
09-02-2018 08:50
Mine isn’t showing I slept at all! 4 nights in a row now. It’s fully charged.
09-02-2018 10:52
09-02-2018 10:52
I have the same problem on my Alta HR. For about two weeks now I’ve been getting only simplified sleep details no matter how charged it is or the position/tightness on my wrist. Will rebooting it clear away all my progress on the app?
09-02-2018 19:41
                              09-02-2018 19:41
Yes, try restarting it several times. You will not lose any data. It is like restarting a phone. Let us know how you go
12-25-2018 17:42
12-25-2018 17:42
My Alta HR did not track my sleep stages last night. I turned the Bluetooth on and off, reset it, tried syncing it and still could not retrieve data. It happened one other time as well. What causes this? Is the data lost? What can I when this happens. Thank you.
 Best Answer12-25-2018 21:04
                              12-25-2018 21:04
12-26-2018 12:37
12-26-2018 12:37
 Best Answer12-26-2018 14:41
12-26-2018 14:41
Hi. Hoping someone can please help. I received a Fitbit Alta hr but it’s not recording ANY sleep simple or otherwise whatsoever. I’ve checked position and tightness of band etc and both are as instructed. Is there a fix to this or do I have a faulty Fitbit? Thanks SarahK.
12-26-2018 20:40
12-26-2018 20:40
 Best Answer03-13-2019 09:57
03-13-2019 09:57
I don’t see a button on my fitbit charger... trying to restart. Fitbit Alta hr
 Best Answer03-13-2019 11:56
03-13-2019 11:56
 Best Answer03-14-2019 05:06
03-14-2019 05:06
I tried putting on charger tapping 3 times with in 4 seconds it vibrates but no logo comes up. Trying to reboot. Trying to get sleep stages only gives simply sleep.
 Best Answer03-19-2019 14:28
03-19-2019 14:28
Hi
The reset button is on the black part that attaches to the metal part you plug in.It's on the opposite side where your battery is charging. Hope this helps.
03-19-2019 14:35
03-19-2019 14:35
Hi Rebecca45
If you are rebooting and the logo is not coming up even though it is vibrating and you are still getting just simple sleep then I would suggest contacting fitbit support on phone.Also, make sure you are not programming in when you go to sleep because that automatically will give you simple sleep and not the detailed version.
