08-20-2018
21:24
20:08
08-20-2018
21:24
20:08
I’ve read other posts. I too am not getting consistent readings of sleep stages. Yes the band is set properly on my wrist. Yes the HR is charged. Yes my heart rate tracks all night. Given everything I’ve read, could it be that Fitbit is having a software problem? Any thoughts? Any suggestions?
07-01-2019 19:17
07-01-2019 19:17
07-13-2019 20:23
07-13-2019 20:23
I’m having the same issue, this definitely seems like a software glitch or a problem with the device itself after a period of time. I have rebooted my Alta HR 4xs and still it does not record sleep stages which is the reason I bought this version of Fitbit.
07-13-2019 22:25
07-13-2019 22:25
07-15-2019 08:34
07-15-2019 08:34
08-08-2019 05:29
08-08-2019 05:29
I’ve had my Alta HR for one month it tracked my sleep for three weeks and suddenly this week it’s not tracking sleep at all. I did re-boot it yesterday and still it’s not tracking sleep at all. I know it is correctly positioned on my wrist and the heart rate monitor is working, any suggestions?
08-08-2019 16:10
08-08-2019 16:10
Hi Hera 525
When you rebooted, did you feel the vibration each time you clicked? If you did, and you are still having issues, I would suggest calling Fitbit support. I have found them to be extremely helpful and patient.
Good luck!
08-10-2019 07:15
08-10-2019 07:15
08-19-2019 06:22
08-19-2019 06:22
Your solution - i.e. not working, we are working on it - was posted a year ago. Has any resolution been found?
Rhonda
08-19-2019 06:26
08-19-2019 06:26
08-19-2019 12:58
08-19-2019 12:58
08-19-2019 13:03
08-19-2019 13:03
08-19-2019 13:11
08-19-2019 13:11
On mine, I had my Alta HR for two years and loved it! It just worked with downloads, sleep, etc. Basically when it started stopping the sleep stages, I rebooted it a couple of times and then it died completely. I ended up getting the Charge 3 version from Costco and really have not liked it nearly as much as the alta HR. It is wider and just does not seem as reactive as the Alta HR. In hindsight, I probably would have purchased another Alta HR rather than this version. Live and Learn!!
08-19-2019 16:31
08-19-2019 16:31
08-19-2019 17:25
08-19-2019 17:25
Hi Hera
So glad that worked for you. It's a matter of how you place the battery in the charger. Hope this help others as well.
08-21-2019 05:43
08-21-2019 05:43
I also have the same problem and was basically told by fitbit to suck it up.I got the fitbit for the sleep stages and am very disappointed.I wonder how long they will be "working on it". Would a new fit bit work?
Very very disappointed in the product and company.
08-21-2019 05:44
08-21-2019 05:44
didnt work
08-21-2019 18:45
08-21-2019 18:45
Hi
I know it's very frustrating when the sleep tracker does not work. Try once more to go through each step. When you reboot, make sure to line up your battery three dots directly on the charger's two metal tiny prongs. You should feel a vibration. Press the black button (very small) located in the black part near the metal part which you plug in. Push button 3 times in 5 seconds, making such you feel the vibration each time. When you go to sleep, make sure you are wearing your fitbit on non dominant hand. That should work. Sometimes it's possible it doesn't work because of a position you may be sleeping in. If this doesn't work try calling fitbit support by phone. They should be helpful. If all fails, them you may have a faulty fitbit and should contact customer service and have them replace it if possible. Good luck.
08-22-2019 06:05
08-22-2019 06:05
08-22-2019 08:46
08-22-2019 08:46
08-23-2019 09:15
08-23-2019 09:15
