08-20-2018
21:24
20:08
08-20-2018
21:24
20:08
I’ve read other posts. I too am not getting consistent readings of sleep stages. Yes the band is set properly on my wrist. Yes the HR is charged. Yes my heart rate tracks all night. Given everything I’ve read, could it be that Fitbit is having a software problem? Any thoughts? Any suggestions?
08-23-2019 09:27
08-23-2019 09:27
08-23-2019 09:45
08-23-2019 09:45
08-23-2019 15:21
08-23-2019 15:21
Hi Hera
So glad to hear an agent was able to help you. It’s good to keep Fitbit support in mind when all else fails.
08-30-2019 06:50
08-30-2019 06:50
Hello all, I hope you are doing fine.
My apologies for the slow reply, I appreciate all the efforts in trying to fix this sleep stages issue. Thanks for the input, @JM914.
@Hera525, @Cearll, @divainprogress, @spokanemichael, @awaller and @RhondaMH, there are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
Let me know how it goes. 🙂
09-11-2019 05:24
09-11-2019 05:24
I've had the same problem for the last two weeks. All of a sudden, I only get simplified sleep pattern. Nothing has changed with how I sleep, how I wear the tracker. etc. I get regular heartrate readings during the day -- and also at night whenever I wake up and look for them. (Obviously, I'm not asleep then.) Rebooting doesn't help.
The tracker is 9 months old. I've had two Altas (not HR) fail in the first year, too, but that was about losing battery charge. Different issue this time. -- Jim
09-24-2019 21:31
09-24-2019 21:31
It's nice to know I'm not alone. For the first 6 months mine worked fine but I've been having similar problems, intermittently, for the last 2 months. Sometimes it rectifies itself, sometimes rebooting the tracker will solve it but it keeps reoccurring. At first it was giving simplified data for the whole night but this week it's been indicating that I slept for a couple of hours, then was awake for 1 to 2 hours, which I know is not correct, then slept again. If the time I sleep after it thinks I've been awake is more than 3 hours then I get full data, if it's less then it's simplified. With so many of us with the same issues it would be nice to have a permanent fix.
09-25-2019 06:03 - last edited on 10-10-2019 16:40 by LiliyaFitbit
Hi,
for about 2 months fitbit was telling me it was a software problem. Finally
after calling every few days and complaining they admitted the fitbit
device was bad, but I was out of luck since it was out of warranty.I did
get a coupon for 25% for a new one.
09-25-2019 09:07
09-25-2019 09:07
That's helpful. I'm still burned from the last time they stalled me past my warranty, but I'm still in warranty so I may hassle them to get a replacement. Not that the sleep info is wonderfully accurate, but it's better than nothing. It's now been a month with no sleep details. The two weeks before that had decreasing details but still occasional readings. Either there's something wrong with my heart rate that my doc hasn't picked up, or there's a hardware problem. I'll give them a call.
-- JS
09-25-2019 17:57
09-25-2019 17:57
Hi Anna
I feel that even though they gave you a 25% off a new fitbit, they should have replaced it since you were calling before the warranty expired. They should stand by their product.
10-03-2019 20:38 - edited 10-03-2019 20:41
Just bought my alta hr. All good for 5 days then sleep stopped tracking. Thought I'd try here for answers. Seriously disappointing to see that this has been an issue for so many users for so long with no fix. Will attempt a reboot but if no joy will be seeking a total refund. Not good enough - surely the bug should have been fixed by now. The complaints on this forum date back over a year now. 🙁
11-20-2019 02:42
11-20-2019 02:42
Emmy fitbit alta hr stopped recording sleep 11/10/2019 and nothing I have tried has improved matters.
This reply from the moderator is over a year old. I just downloaded the November 2019 app and got no improvement. If you have been working on this for over a year, what new answers have you found? Rebooting the watch is pretty sad stuff.
11-20-2019 06:15
11-20-2019 06:15
11-20-2019 06:23
11-20-2019 06:23
11-20-2019 07:10
11-20-2019 07:10
Did Fitbit give you credit for a new one?
11-20-2019 09:02
11-20-2019 09:02
11-20-2019 09:14
11-20-2019 09:14
11-20-2019 10:44 - last edited on 02-06-2020 13:32 by LiliyaFitbit
i was persistent. called every other day for a few weeks
11-25-2019 16:26
11-25-2019 16:26
Reboot does not fix the sleep stage issue
12-28-2019 05:13
12-28-2019 05:13
My Alta HR suddenly started skipping reporting any sleep. I do not even get a simplified sleep report--just nothing as if I had not slept. I charged it and kept it snug on my wrist. Is there a problem with the tracker?
12-28-2019 09:34
12-28-2019 09:34
Same problem here. I have been back and forth with customer support for weeks now and it’s only gotten worse.
