Alta HR not turning on
I just got a new alta hr. It is doing absolutely nothing. I have tried many times to turn on and nothing is happening. I have tried to put on charge and can't get anything to happen. Bluetooth  won't do anything cause it will not turn on. Should there be any battery charge at all to show that it should turn on. When I put on charge It doesn't  show any lights or the vibrate that it says it should do. What should I do? I have tapped and nothing happens, I have tried to charge and no sign at all that it's charging. Have checked connection to make sure pins are touching and they are.  Thank you for any advice.
Moderator Edit: Updated Subject for Clarity
42 REPLIES 42
@Dansmama3  Sorry to hear you are having some difficulties.  Here is a link to the user guide in case you haven't seen it.  It walks you through the set up process and all.
Maybe that will help you get it set up~
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
@Dansmama3 Welcome to the Fitbit family! Are you still experiencing this issue?
If it is not showing anything on its display when you plug it in to the charging cable; I recommend performing a restart on your Alta HR. That should certainly help fixing this issue. You can try this a couple of times.
Try that out and let me know how it goes! Smiley Happy
Santi | Community Moderator, Fitbit
Like my response? Vote for it! Also, accept as solution!
Just received a new Alta HR and cannot get it to turn on or synch.  It is fully charged and the screen displays only "www.fitbit.com/setup".  No matter how many times I tap it, that's all I get.  With that on the screen it will not synch to my iPhone.  I believe when it is on, it should say "HR".  I have tried restarting the device with the USB button multiple times.  Is the device defective...as I am about to return it?
@RCT2  Your Alta hasnt finished setting up so you cant get started yet. Have a read of this Help Article. Let us know how you go.
Troubleshooting Setup
Community Council Member
Helen | Western Australia
@RCT2 Welcome to the Fitbit family! I see that @NellyG provided a link with some troubleshooting steps you can try to get your Alta HR to set up with your iPhone. I just want to make sure that you have tried them already and want to know if you still need help with this?
What iPhone do you have? Is it under the list of supported devices
You can also try setting it up using a computer if needed.
Please keep us posted so we can keep helping you out! Smiley Happy
I'm having this problem - did you manage to solve it?
Yes, I should have thanked Nelly earlier for her response and help.  I followed the link that Nelly provided and was able to set it up with no problem.  HOWEVER, I needed to delete and reinstall the app on my iPhone first.  I think once you are unsuccessful setting it up, the iPhone app has problems, so best to start clean.  Hope that helps.
Thanks for your response. Had tried deleting app & every other trouble
shoot but customer service think there may be an issue of connectivity so
am, sadly, sending it back for a replacement.
I was having a similar problem but verifying my email through Fitbit's email actually fixed it for me.
Where is the link please? I'm having exactly the same problem.
Do you wantbthe link to Customer Support? (If it is another link let me know what it is you need)
Contact Support
 Just purchased my Alta HR and it's faulty out of the box. Looks like hundreds of others are having issues with it dying. Restarting only helps for a little bit.
Hey folks, Google "Alta hr keeps dying" or something similar and you'll find a bunch of open cases that are not solved.
Telling people to restart the device is not a solution.
Fitbit Alta HR, Gunmetal Series, purchased October 2017
Charging usb cable dosnt have a reset button on it
@Williamfitch3 If there is no button itis probably not a genuine Fitbit cable. But look closely at the black plastic on the USB end - that is where it should be.
My charging cable doesn’t have the restart button. Is there a way to get the correct cable without sending the whole thing back?
You need to contact Support if fitbit supplied a charger without a button. Usually the cables without buttons are third party ones, not supplied by Fitbit. But if you have a genuine fitbit one with no button you need to talk to fitbit. Support link in my signature
I have the same issue.  It’s been charging for about 6 hours.
Any solution?
Then trybthe restart suggeztion above and if that doesnt work contact Support (link in my signature )
Hi @NellyG, my Fitbit Alta HR is dead out of the box. I Unboxed it, plugged it & nothing! Black screen no matter how many chargers I used (including Mac laptop). I tried the reset button & still nothing. No light, no vibration no nothing!
worst part is that I got it as a farewell gift as I left a country (S.korea)& now unboxed it in my new country half way across the world (Netherlands). Not even sure if the warranty will hold or where to take it. Is this problem solvable or do I have to spend time looking for Fitbit stores?!
