09-08-2023 06:05
09-08-2023 06:05
Brand New Alta HR and it will not show steps in the display. Instead it reads K. My profile is setup correctly and I know it is syncing with my app. Any suggestions?
09-08-2023 06:20
09-08-2023 06:20
Hi @Trinityfarm This is a common complaint with new Alta owners. When you are using a vertical clockface (the default face is vertical), there is not enough room for the display to show the whole step count so it is rounded to the nearest thousand steps and displays as 4k - meaning 4000 steps. If you want to see the exact number of steps you need to change to a horizontal clock face in the App. Enjoy your new Alta HR
Helen | Western Australia
Best Answer09-08-2023 06:20
09-08-2023 06:20
Best Answer09-08-2023 06:24
09-08-2023 06:24
Best Answer09-08-2023 06:25
09-08-2023 06:25
You are correct! Thank you. I changed the clock face to horizontal and it now reads steps.
Best Answer09-09-2023 05:48
09-09-2023 05:48
@Trinityfarm I want to share some important information about your new Alta HR
Laurie | Maryland
