Alta HR won't charge
Hey, I just bought Fitbit Alta HR and tried to set it up, but device doesn't react at all. It doesn't show that is being charged (yes, I plugged charger right) or set up link on its' screen. Tried to tap its' screen, reboot a few times - nothing. Feels like I just bought already broken device.
Maybe somebody else had same first experience, but everything turned out OK? Or I should ask vendor for a refund?
Help!
3 REPLIES 3
Welcome to the Community, @kndrtt.
Thanks for troubleshooting this turning on issue. If your Alta HR isn't charging or responding, I recommend taking a look at the help article: Why isn't my Fitbit device's battery charging? and follow the instructions provided there.
Let me know the outcome. 🙂
Hey, thank you for your response.
I brought it back to the suppliers and they tried to troubleshoot the problem, but still same result - device didn't react to anything. They said they never had similar situation to mine. So waiting for their last response - whether they managed to fix it somehow or whether they will change it into another one.
Thanks for the update, @kndrtt. It's great to hear that you are working with the supplier this problem, I know they will be glad to help you out and provide you a solution.
Keep me posted. 🙂
