Alta HR won't hold a charge
My tracker recently started turning off and have had to restart it. After not wearing it for about 5 days the charge seemed to be holding. So I started to wear the tracker. Several hours later it had turned off again? When I restarted it the charge was about 60 %. There seems to be a lot of issues with these trackers doing this. So could this be an issue with the battery life?
3 REPLIES 3
Hey, thanks for your participation in the Forums.
I appreciate all the efforts in trying to fix this battery issue. I recommend taking a look at the help article: Can I extend my Fitbit device's battery life? and follow the tips provided there. After following them, test the unit.
Let me know the outcome.
Is it synced to your phone or laptop etc? Mine wouldn't hold charge and i discovered it had disconnected itself from the phone app. As soon as i synced it again it has held charge fine x
Welcome to the Forums, @mtg35. I appreciate the tip provided, I know our friends will find your post really helpful.
Keep the stepping up!
