Alta HR won't hold a charge
Since the 7/6 update my battery has slowly stopped holding a charge. I did the full charge, followed by letting it completely drain that customer support required. It drained in 2 hours. Before 7/6 it held a charge for 4 to 5 days. CS's 9nly option is to buy a new one. Has anyone figured out how to undo the update?  Or turn off All Day Sync?  The toggle for ADS is now gone.
1 REPLY 1
Welcome to the Community, @CBH1234.
Thanks for troubleshooting this battery issue. Since you have already opened a case with support, I recommend keeping in touch with them. I know they will be glad to help you out and provide you a solution.
In the meantime, let me know if you need anything else.
