09-26-2023
11:16
05:40
09-26-2023
11:16
05:40
I have a fully updated Android phone and have done Bluetooth restarts, restarted the Alta Hr, and restarted the phone multiple times. The screen just says "www.fitbit.com/setup." Only time it changes is when I need the pairing code. After entering the pairing code, it goes back to "www.fitbit.com/setup" despite continuing with the setup process on the phone. The phone recognizes that the device is paired and ready for use, but the device shows nothing except the "www.fitbit.com/setup"
I know these devices are discontinued. Does that mean they dropped all support for the devices and now they are completely unusable?
09-28-2023 05:41
09-28-2023 05:41
Hi there, @uspsdave. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Alta HR and taking the time to troubleshoot it before reaching out.
As our last resort, I'd recommend trying the following steps in the order listed:
09-29-2023 05:15
09-29-2023 05:15
I have exactly the same issue.
This can't be a coincidence!
10-12-2023 13:45
10-12-2023 13:45
+1 did all the steps mentioned above, but now I cannot even connect my Alta HR anymore.
11-02-2023 00:32
11-02-2023 00:32
This is me too!
I've tried everything.
Can't be a coincidence that some of us are experiencing the same thing at the same time.
11-07-2023 06:44
11-07-2023 06:44
Quick update!
I spent an hour on chat trying to sort mine out.
Guess what... nothing worked!!
However I've been sent a discount code for a new one which is great,apart from the fact there's nothing wrong with the device itself, it's working fine 😞
I guess they tried.
