02-03-2021 08:45
02-03-2021 08:45
Hi
My alta screen has stopped working. The first step to try and fix this is to restart the device using the charger and press the button 3 times. When I do this, nothing happens. The device does not restart.
Can you help please?
02-03-2021 09:14
02-03-2021 09:14
Hi @louisepat have you tried using a different usb port? I have one port on my computer that doesn't work and when I use it, I can't restart my Fitbit. Keep trying to do the restart. Other than that, is the screen response to taps?
02-03-2021 09:52
02-03-2021 09:52
02-03-2021 11:37
02-03-2021 11:37
I'd probably keep trying to restart it @louisepat but it's possible the Alta HR has died. You probably are past warranty, too.
02-03-2021 22:00
02-03-2021 22:00
02-03-2021 22:03
02-03-2021 22:03
You clean all the connector pieces on the charger and Alta HR? There's not much that can be done if you're out of warranty. The restart button is used a lot for minor problems.
