11-27-2022
04:29
04:52
11-27-2022
04:29
04:52
Finally sorted out the alarm problem - kind of - and now for the last three days the sleep is not analysing- so fed up!
11-28-2022 04:54 - edited 03-16-2024 09:53
Hi there, @Luvurminimum. Thanks for stopping by in the Community Forums. I'm glad to hear you managed to solve the issue you had with the silent alarms. We‘re taking your comments and sentiments in regards to our products into consideration.
Regarding your sleep data, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Hope this helps.
11-28-2022 05:34
11-28-2022 05:34
12-01-2022 06:00
12-01-2022 06:00
I tried the begin sleep but you don’t get the same analysis - don’t like it!
This Fitbit was fine until the alarms started playing up - I haven’t changed the way I wear it, always the same as recommended by Fitbit - I don’t understand why everything is becoming intermittent
