03-16-2019
23:09
20:08
03-16-2019
23:09
20:08
I charge my Fitbit Alta HR yesterday night before I sleep then morning when I take it there is no power is in nothing even the vibrate when I plug it again to charger no response.
Please help me.
03-17-2019 04:53
03-17-2019 04:53
Hi @cmikiako Try restarting it several times and then leavebit on charge for a coiple of hours. If there is still no sign of life repeat the restarts etc. Bybthe way, how long have you owned the Alta HR?
Helen | Western Australia
09:12
11:31
03-18-2019
09:12
11:31
Welcome to the Community @cmikiako and @NellyG thanks for the input.
I appreciate all the efforts in trying to fix this display issue by yourself and was able to see here that our friend @NellyG provided some instructions in order to fix this issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. ![]()
Best Answer03-19-2019 05:33
03-19-2019 05:33
How do I restart my fitbit? I accidentally charged it all night, now it isn't doing anything. I see some people say to restart, but I don't know how?
04:18
11:30
03-20-2019
04:18
11:30
Hey @MrsMiracle, welcome to the Forums!
If you want to restart your Alta HR, you just need to do the following:
Catch you later. ![]()
01-15-2020 04:51
01-15-2020 04:51
Before my screen went blank I had an exclamation point on the screen in a bubble (I think). I've tried to reset it a few times but the watch doesn't even register the charger connecting to it? It's definitely charged but looks dead, is there any other way of diagnosing it? I've had the watch for 2 years now
01-27-2020 09:44
01-27-2020 09:44
I'm having the exact same issue, and I've also owned mine for 2 years.
I didn't charge overnight though. It was working at the gym, and by the time I went to shower later, it wasn't working at all.
Let me know if you figure anything out!
01-27-2020 12:25
01-27-2020 12:25
I am having the same problem, it isn't charging
Best Answer01-28-2020 03:05
01-28-2020 03:05
Even though I was only 2/3 weeks after the warranty expiry, Fitbit only have me a discount code for a new one so if resetting it doesn't work there's no other option. I moved to garmin for as their customer service is better. Good luck.
05-30-2020 12:53
05-30-2020 12:53
I have the same problem with my fit it and when I connected it to the charger I can't feel the vibration when they connect
Best Answer05-31-2020 00:38
05-31-2020 00:38
Best Answer06-06-2020 09:44
06-06-2020 09:44
What do you do if there is no charge, no vibration, no light, etc., once you have tried to charge and reboot multiple times at different times ? Everything appears to be connected accurately, and I have pushed the reboot button 3 times within 8 seconds multiple times. (I let it sit as well for a while) It just doesn't want to turn on today, and was working absolutely fine yesterday. Can anyone tell me what the issue is?
thanks!!!
06-07-2020 03:13
06-07-2020 03:13
06-07-2020 09:49
06-07-2020 09:49
I am having the same issue. Was working fine yesterday, this morning won't turn on. Plug it in, doesn't even act like it's connected to a charge, pushed the button, no logo and sitting on the charger - nothing is working...
06-07-2020 17:25
06-07-2020 17:25
06-08-2020 18:26
06-08-2020 18:26
This keeps happening to me. I have to go through the steps to restart multiple times, and eventually it restarts. Then it flakes out again. I have had to restart it 5+ times in the last 3 days.
Best Answer06-08-2020 19:00
06-08-2020 19:00
Best Answer06-09-2020 17:48
06-09-2020 17:48
I have never had a problem and then yesterday it dies. If I connect it to the charger it charges - currently 100%. As soon as I disconnect from the charger it does again. We’re you able to actually speak to someone?
06-10-2020 19:41
06-10-2020 19:41
Best Answer06-19-2020 14:30
06-19-2020 14:30
This just happened to me today. Never had any issues before. I also don't ser any buttons anywhere.
