12-19-2019
08:51
20:01
12-19-2019
08:51
20:01
I've had an Alta HR for about 1 year. When I check my phone, it is logging everything but when it is on my wrist, it won't light up. It shows nothing. When I plug it in, it lights up but won't stay on. Is their anyway to fix this?
12-19-2019 12:18
12-19-2019 12:18
Hello and welcome to the Fitbit Community @TX1
I would suggest restarting your Alta HR to see if that resolves the issue. You will not lose any data doing this.
Here’s how:
😃 Please let me know it this resolves your light display. Keep me posted
12-19-2019 12:18
12-19-2019 12:18
Here’s how:
12-20-2019 05:50
12-20-2019 05:50
Welcome to the Community, @TX1 and @SunsetRunner, thanks for the input.
I was able to see here that our friend @SunsetRunner provided some instructions in order to fix this turning on issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. 🙂
12-20-2019 10:04
12-20-2019 10:04
12-20-2019 10:06
12-20-2019 10:06
This worked. Thanks for your help!
04-29-2020 03:00
04-29-2020 03:00
HR Alta Fitbit not lighting up when tapped. I have selected the button on the charge 3 times, it vibrates and takes a charge. It still will not light up. It has been tracking tracking sleep and steps however, will not light up except once every once in a while. Is it time for a replacement?
Best Answer04-29-2020 10:25
04-29-2020 10:25
I tried all of the trouble shooting, including letting it plugged for 30 minutes more even if the battery was loaded (following a chat) and it did not work. Still black. What's next?
Best Answer07-27-2020 05:43
07-27-2020 05:43
My Alta HR IS NOT lighting up,I tried to reboot but it still is not lighting up. Help!
Best Answer07-27-2020 14:03
07-27-2020 14:03
I tried your suggestions but my charging cable doesn’t have any buttons on it. Is there another way to make it turn on?
Best Answer08-02-2020 10:35
08-02-2020 10:35
My device will only turn on while on charger. Takes charge and syncs to my phone no problem. But as soon as disconnected from charger won't turn on or track activity. My charger does not have any buttons. I reset it and reinstalled and synced on my phone. Still nothing! 😔
Best Answer08-02-2020 16:01
08-02-2020 16:01
Best Answer08-02-2020 20:23
08-02-2020 20:23
Same thing just happened to mine
Best Answer08-02-2020 21:26
08-02-2020 21:26
Best Answer06-05-2021 14:28
06-05-2021 14:28
Tried restarting it pushing the button 3 times and it and it still won't restart. Sorry. I've tried this 3 times already
