Alta HR won't work unless it's connected to the charger
ANSWERED
I've press the button on your charging cable 3 times within a few seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into my computer. Then I see the Fitbit logo and the tracker vibrates, which means the tracker has restarted. Finally I unplug my tracker from the charging cable and it goes completely dead.  HELP!
1 BEST ANSWER
Accepted Solutions
Hi @lamelita75 If the restarts you are doing are not reviving your Alta HR then sadly it is dying and there is nothing you can do. Sorry.
Community Council Member
Helen | Western Australia
5 REPLIES 5
Hi there, @lamelita75. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Alta HR before reaching out. @NellyG Thanks for your help!
As a first approach, please confirm that you've restarted your Fitbit device as suggested here
If the issue persists, please see Why isn't my Fitbit device's battery charging?
I am currently having this same problem with my Alta. I have tried the restart as well by clicking three times. Nothing is working
Hello @Tysam23 and welcome to the Community.  I looked at your public profile and can see that you are a new user.  The Alta was first released in 2016 and discontinued in 2018.  Rechargeable batteries degrade, even when they aren't used.  Even if sealed in an original package.  I believe you have a dead battery.  I also unchecked that Best Answer and updated it to the correct answer.
Laurie | Maryland
Identical problem occured yesterday as described by lamelita75 and Tysam23. Went through same restart steps. Nothing.  Apparently my Fitbit has died.  Since I sync on laptop and all new Fitbit devices require syncing on tablet or smartphone, I'm now a former Fitbit user since I have neither and have no plans to buy. I enjoyed my Alta HR for almost 5 years.
