08-20-2022
11:51
07:14
08-20-2022
11:51
07:14
I've press the button on your charging cable 3 times within a few seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into my computer. Then I see the Fitbit logo and the tracker vibrates, which means the tracker has restarted. Finally I unplug my tracker from the charging cable and it goes completely dead. HELP!
08-21-2022 05:50
08-21-2022 05:50
Hi @lamelita75 If the restarts you are doing are not reviving your Alta HR then sadly it is dying and there is nothing you can do. Sorry.
Helen | Western Australia
Best Answer08-21-2022 05:50
08-21-2022 05:50
Best Answer09-06-2022 07:16 - edited 05-29-2023 08:02
Hi there, @lamelita75. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Alta HR before reaching out. @NellyG Thanks for your help!
As a first approach, please confirm that you've restarted your Fitbit device as suggested here.
If the issue persists, please see Why isn't my Fitbit device's battery charging?
Best Answer05-28-2023 19:21
05-28-2023 19:21
I am currently having this same problem with my Alta. I have tried the restart as well by clicking three times. Nothing is working
Best Answer05-30-2023 09:39
05-30-2023 09:39
Hello @Tysam23 and welcome to the Community. I looked at your public profile and can see that you are a new user. The Alta was first released in 2016 and discontinued in 2018. Rechargeable batteries degrade, even when they aren't used. Even if sealed in an original package. I believe you have a dead battery. I also unchecked that Best Answer and updated it to the correct answer.
Laurie | Maryland
Best Answer06-02-2023 14:25
06-02-2023 14:25
Identical problem occured yesterday as described by lamelita75 and Tysam23. Went through same restart steps. Nothing. Apparently my Fitbit has died. Since I sync on laptop and all new Fitbit devices require syncing on tablet or smartphone, I'm now a former Fitbit user since I have neither and have no plans to buy. I enjoyed my Alta HR for almost 5 years.
