Alta HR works on charging cradle but turns off once released
Hello, i have searched for this issue, but can't find the answer. I have an Alta HR. When it is plugged into the charging cradle it works and i can sync it to my iPhone app. However, once i take it out of the cradle it seems to die. The screen is blank and unresponsive. Can you anybody advise?
Thank you!
10 REPLIES 10
Just to add, i have reseted, using the button on the cable a few times and it still does the same
I have also done the same
Any luck?  Mine just started this today.  I have had it a little over a year
You might get another two weeks and you will end up called no Customer Service
Sent from my iPhone
Thank you.
Sent from my iPhone
Mine just started doing the same thing yesterday.  I have also reset the fitbit a few times.  Any updates on what happened to yours?
I believe it's dead.  I have restarted it many times.  I works for about a minute and then turns off.  From all the posts it appears that the Alta HR is made to work for about a year or so.  That way you have to buy a new one.  Not this girl.
Thanks for the reply. I chatted with a rep and he basically told me I had
to replace it with a newer model since alta's are no longer made. I got
mine just over 2 years ago and of course the warranty is only good for
one year.
I chatted with a rep and he basically told me I had to replace it with a newer model since alta's are no longer made.  I got mine just over 2 years ago and of course the warranty is only good for one year.
I replaced it with another Fitbit
Good Luck
