03-18-2016 21:21 - last edited on 08-20-2020 18:43 by MatthewFitbit
06-11-2016 17:49
06-11-2016 17:49
06-14-2016 06:01
06-14-2016 06:01
Welcome to the Forums @Kate62! Are you still experiencing syncing issues:
I would recommend the following troubleshoots to help you get back on track with syncing your Alta:
1. Restart your Alta, click here for instructions.
2. Reboot your iOS device.
3. Open your iOS settings, turn off Bluetooth for 10 seconds, and then turn it back on.
4. Open the Fitbit App to initiate a sync.
Hope this helps!
Nice work @rudysmom and @NKGME! Now, let's get back to stepping!
06-16-2016 17:39
06-16-2016 17:39
My alta isn't found my my iphone blue tooth, it previosuly was. I have deleted the app and put it back. I went into my phone's setting and to check my text notifications that is on as well as the fitbit app notifications, but still no connections. Any suggestions?
06-17-2016 05:21 - edited 06-29-2016 10:06
Welcome to the Fitbit Community @Dawn_M! You can follow our friend's @SunsetRunner sync troubleshoot for iOS devices to try to sync your Alta with your iPhone again.
I hope this helps. See you soon!
06-17-2016 07:05
06-17-2016 07:05
06-18-2016 05:08
06-18-2016 05:08
It's nice to have you on board @Sufit. Please try the Syncing troubleshoot for Android app that our friend @SunsetRunner has shared with us.
Welcome to the Community!
06-28-2016 03:38 - last edited on 06-29-2016 10:05 by AndreaFitbit
I just bought a FitBit Alta after owning a FitBit Charge for the past 2.5 Years...
I have followed all of the same steps as above, and I am having the same problem. Very frustrating.
It will Not sync / update. I have installed and reinstalled the doggle and the software on my mac. I have installed and deleted the app to my phone. My iPhone searches and searches for the FitBit Alta signal, only to give me this error message: "Unable to Start Firmware Update - Firmware update cannot be started right now because the system is busy. Try again in a few minutes."
Please know that I just rec'd my Alta five days ago, and it updates (syncs) every other day. So, this tells me that there is No problem with my iPhone or my Mac .. the problem is the FitBit Alta.
*****NOTE: The Alta does not count stairs!! So, after two years of collecting badges for stairs, FitBit introduces a product that doesn't???? I Can Not Figure that one out ... I am sooo disapointed at FitBit for this one.... I am sending it back, and requesting that FitBit make a slimmer band that does not take away from the challanges they created. Yes, I understand the altimeter sensor didn't fit, and it would not fit in the Alta... but they should notify Current Users at Checkout ... And WHY Did they call it an ALTA if it does Not Have an ALTI????
Moderator edit: format.
06-28-2016 06:57
06-28-2016 06:57
06-28-2016 18:44
06-28-2016 18:44
06-29-2016 10:20
06-29-2016 10:20
Nice to see you here @cFaLk, @DvG and @Shea_in_Houston! Please follow @PeterFitbit sync troubleshoot for iOS devices to try to sync your Alta with your iPhone again.
Are you still getting the firmware update message @cFaLk? Thank you for the altimeter feedback. You can vote for our Next Generation Alta with altimeter Feature Request.
It's nice to have you on board!
06-30-2016 11:06
06-30-2016 11:06
Thank you so much! I was having trouble getting my iPhone 5S to detect my new Alta to set it up, and pressing the button on the charging cable fixed it! Syncing just fine now! 🙂
07-01-2016 07:30
07-01-2016 07:30
Welcome to the Forums @ElectricUnicorn . I'm glad to hear that pressing the button on the charging cable fixed your syncing issues and your Alta is syncing fine now.
I also would like to encourage you to spend a good time sharing your experiences with other friends in our Discussions board. I'm pretty sure you'll have lots of fun!
08-16-2016 13:48
08-16-2016 13:48
open the fitbit app, hit account bottom right corner, hit alta, scrol down halfway to bottom and turn on all day sync, it will ask you if you want to pair bluetooth with alta hit yes, after it is paired turn the all day sync off again.
this worked for me.
08-16-2016 13:55
08-16-2016 13:55
Open Fitbit app, hit account bottom right corner, scroll down to all-Day sync and turn it on, this should prompt to pair bluetooth with Alta, hit yes once paired you can then turn off all Day sync
08-17-2016 07:19
08-17-2016 07:19
Welcome to the Fitbit Community @Jaroekle! Thank you for your amazing advise! It could be helpful for some users.
Keep participating in the forums and if you have more questions, don't hesitate to come back!
09-24-2016 14:07
09-24-2016 14:07
09-27-2016 06:20
09-27-2016 06:20
Welcome to the Fitbit Family @Julesmck01! I'm glad to hear you were able to sync your device!
Thank you for sharing your tip with us! I also would like to encourage you to spend a good time sharing your experiences with other friends in our Discussions board. I'm pretty sure you'll have lots of fun!
Nice work! Now, let's get back to stepping!
10-03-2016 02:05
10-03-2016 02:05
10-03-2016 16:08
10-03-2016 16:08
10-04-2016 00:15
10-04-2016 00:15
