03-18-2016
21:21
18:43
03-18-2016
21:21
18:43
10-05-2016 07:32
10-05-2016 07:32
Hey hey hey, thanks for stopping by @Klutzy9118 and @Jaroekle. I'm glad to hear that you were able to sync your Fitbit Alta @Klutzy9118. @Jaroekle, thank you for sharing your advice!
We have begun to roll out a new Fitbit Firmware for the Fitbit Alta, version 21.37.8. This is a progressive rollout, and all customers can expect to have it within a few weeks. We roll out releases in phases as a cautionary measure so we can monitor performance closely and make adjustments if needed. This release resolves an issue where some customers had difficulty syncing.
Thanks for being part of the Community!
10-05-2016 08:10
10-05-2016 08:10
10-05-2016 11:15
10-05-2016 11:15
Hi @Klutzy9118! Please Contact Support. They will take good care of you. Remember to tell them that you have tried all the solutions (describing them), so it can be solved faster.
Keep me posted!
10-14-2016 00:08
10-14-2016 00:08
This fixed my issue! Thank you
10-18-2016 07:55
10-18-2016 07:55
Welcome to the Forums @Shellellen! I'm glad to hear that your issue was fixed.
I also would like to encourage you to spend a good time sharing your experiences with other friends in our Discussions board. I'm pretty sure you'll have lots of fun!
11-30-2016 08:59
11-30-2016 08:59
This worked for me. I had the same issue, and this solution worked.
11-30-2016 11:59
11-30-2016 11:59
Welcome to the Community @rothenberger26! It's great to hear that you're back on track. 🙂 Have you checked our Discussions board? There you can share your story, find some fitness tips,recipes and more! Give it a look!
See you around!
11-30-2016 12:10
11-30-2016 12:10
So, why doesn't FiTBiT tell us during the checkout process that the Alta Does NOT have the ALTI Sensor in it for Counting Stairs?? How can they create a new product called 'ALTA' and promote it to many Faithful LoVERS of FiTBIT (that all collect Badges) ... and then promote that NEW product, BUT Takes Away A Feature... Crazy & Soooo Sad!
They should add a Box During the CHECK OUT Process that says, "Already a FiTBIT Owner" ..and then have something pop up that says, "This Does Not Count Stairs" ....
It's soooo misleading!
12-01-2016 05:23
12-01-2016 05:23
12-02-2016 17:14
12-02-2016 17:14
I've done everything except restart fitbit. I don't want to lose my data. This is the second ttime this has happened, it is very frustrating. I don't see any replies to same question,.
12-06-2016 05:48
12-06-2016 05:48
Welcome to the Community @DotV! Your tracker stores your data for up to 7 days and when you sync your data is stored in the Fitbit servers don't worry about it and try the restart, this will refresh the internal logs of your tracker and will your tracker to be synced.
Let me know it goes, I'll be around!
01-07-2017 03:18
01-07-2017 03:18
Does not sync automatically. Have to keep resyncing on iPhone and iPad. However Bluetooth is continually searching for watch app when I look. I don't have a watch?
01-07-2017 14:07
01-07-2017 14:07
Help connecting Alta to IPhone.. Bluetooth. Any locate
02-01-2017 20:59
02-01-2017 20:59
Unable to sync my iphone to my Fitbit Alta. Just stopped today. Very frustrated
02-02-2017 06:00
02-02-2017 06:00
Thanks for visiting the Community @Deedal @Gurney @Scruffy1985!
If you have already tried doing the restart several times and still not syncing, check out the Syncing Troubleshoot for iOS devices and keep an eye on it.
Keep me posted
03-31-2017 04:05
03-31-2017 04:05
I had the same issue. My Alta stopped syncing while I was at the gym and I freaked out. I tried restarting my iPhone, deleting and reinstalling the app but nothing worked until I restarted my Alta. I had to do it about three times. It finally connected to my phones Bluetooth and within 5 minutes, it synced on my app! Hope this helps 🙂
03-31-2017 13:35
03-31-2017 13:35
It's great to see new faces around @LadyFerg!
It's great to hear that you're back on track! Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
Hope to see you posting more often!
04-05-2017 10:11
04-05-2017 10:11
Thank you! After searching the Alta Board for messages related to sync and iphone, I finally found an answer that helped me. I got a new iphone 2 days ago, but my old one is still here in my desk and that is why it was not updating my new iphone. As soon as I deleted the app off the old iphone, the new one sync(ed?).
04-05-2017 12:03
04-05-2017 12:03
Thanks for visiting the Community @kwallace!
I'm happy to here that you have found the answer within the community. I invite you to check the Discussions board where you can find several topics that might you might find interesting.
04-12-2017 11:08
04-12-2017 11:08
I cannot get my alta to sync with my iPhone. This just started today, has been working fine. Bluetooth connected, turned phone off completely. Any suggestions?
