03-18-2016 21:21 - last edited on 08-20-2020 18:43 by MatthewFitbit
05-17-2018 12:37
05-17-2018 12:37
How you manually do it
05-23-2018 08:04
05-23-2018 08:04
Welcome aboard @Mrskwilliams!
Thanks for sharing your inquiry, let me help you out. To manually sync your tracker follow the instructions listed on this article, there you'll find the steps for all the different platforms.
Let me know how it goes!
06-01-2018 01:33
06-01-2018 01:33
My Fitbit will not sync with my android phone
06-01-2018 06:41
06-01-2018 06:41
06-01-2018 07:21
06-01-2018 07:21
Help.......I had a Charge 2 and now I have an Alta that won't connect like everyone else. Actually it will connect because it shows up on my bluetooth list but when I put in the code it gives me a error500 message!?
06-07-2018 06:40
06-07-2018 06:40
Welcome aboard @Jaymep!
Let me help you out with your inquiry, as a first step I recommend performing the restart. If you're still getting trouble I recommend following these syncing troubleshoots and keep an eye on it.
Keep me posted!
01-07-2019 12:45
01-07-2019 12:45
My new Fit Bit won’t sun to my iPhone & only displays the www. Fitbit & not the date. I have turned Bluetooth on & off as well as my phone & deleted & reloaded the app. What else can I do? It is fully charged. Thx!!
02-06-2019 13:50
02-06-2019 13:50
Alta won’t Sync to my iPhone
08-04-2020 13:34
08-04-2020 13:34
Same here. Worked for 4 hours this morning, then at noon time it quit syncing. Turned off bluetooth a million times, deleted app, reinstalled app, deleted device from bluetooth and app and reinstalled on both. Nada
08-04-2020 13:35
08-04-2020 13:35
I don't have a button on my charger. Couldn't find original charger. Had to order another one
