03-15-2016 14:51 - last edited on 08-20-2020 18:43 by MatthewFitbit
I got my Alta today and I've had it plugged in and charging for over 2 hours now and it won't turn on. If I tap the screen nothing happens, I've tried restarting it too. Any suggestions?
03-16-2016 15:20
03-16-2016 15:20
Hi @hhayter I'm glad to see you on the Community. It's Amazing that you are already using your Alta. Restarting the device should usually do the trick. Connecting the Alta can be a bit tricky. I had a bit of a hard time the first time I charged. Before trying the restart once more please make sure the charging clip is having a proper contact with your Alta's contacts. There is an interesting conversation on how to charge the Alta with some pictures and advice. If the connexion is not working restarting will not work either. Can you verify if the contacts are properly aligned as per the help site instructions.
Let me know if the contacts were the issue. See you soon!
03-16-2016 17:50
03-16-2016 17:50
I have the same problem - my Alta will not turn on.
I just got my Alta today and during the set up process it tried to update and it said it would take up to 10 mins. 30 minutes later there was no progress. But the Alta did display to show it was charging. I then visited the troubleshooting page which said to try restarting the Alta. I did that, and it went dark and never came back on. It was connected properly to the charger as it was charging and I was able to restart it. Now I have a brand new Alta that doesn't work at all and over a 2 day wait for customer service 😞
03-17-2016 09:47
03-17-2016 09:47
Having the same problem. The band has been plugged in for probaby 3-4 hours and no response from tapping on the front of it.
03-17-2016 10:08 - last edited on 11-21-2016 09:23 by AnnieFitbit
I am struggling..charged just fine but will not sync...I am pretty sure it is turned on as the screen lights up to say it is charged and then says fitbit.com/set-up sooooo I am assuming this means it is on..but my phone bluetooth cannot find it..I have turned phone on/off I have uninstalled and reinstalled the software and restarted phone etc...very frustrated.....this is not my first fitbit so I expected better...but I am not liking the idea of a "tap to turn on" screen..grrrr...help....am on verge of sending back
Moderator edit: Format.
03-17-2016 17:00
03-17-2016 17:00
I have the same problem. Just got fitbit Alta today, and it has been plugged in properly. It indicates that it's charged, and sometimes when I tap it gives me a fitbit.com/setup salue. But then it goes dead. I reset 3 times so far. I threw all the packaging in the bin, but I guess I will fish it out from the coffee grinds and fish bones and send this thing back to Amazon.
03-18-2016 03:41
03-18-2016 03:41
03-18-2016 05:03
03-18-2016 05:03
03-18-2016 19:14
03-18-2016 19:14
I am on my second Alta in five days. Same problem. Will not charge. If it is an issue that the charger does not snap into the proper place to charge, then Fitbit has really screwed up.
What are they doing to fix this?? Never had an issue with my ole One.
03-18-2016 19:54
03-18-2016 19:54
03-20-2016 18:39
03-20-2016 18:39
03-21-2016 07:46 - last edited on 11-21-2016 09:24 by AnnieFitbit
It's been over 4 days without any response from customer service on this issue.
03-22-2016 06:41
03-22-2016 06:41
03-23-2016 04:59
03-23-2016 04:59
Just got my Alta yesterday. Had the same issues as everyone else while using an Android phone. Did my research on here and was just frustrated. So I turned to my Surface with Win10. Installed the app and it recognized my device. Went through the process and the Alta was finally working. And then, just for the fun of it, I went back to my phone and tried syncing again. Lo and behold the darn thing worked. So my suggestion is to try to sync with a computer using the little dongle and, if that works, to then sync to your phone. Hope that helps.
03-24-2016 14:52
03-24-2016 14:52
03-24-2016 14:55
03-24-2016 14:55
03-25-2016 04:22
03-25-2016 04:22
See my post above about trying to sync to a computer first. The unit doesn't turn "on" until it is synced.
03-28-2016 11:30
03-28-2016 11:30
This worked for me as well
03-28-2016 13:04
03-28-2016 13:04
I have the same problem. Took it out of the box, fitted the charger and nothing. Re-set button makes no difference whatsoever. I'm at a loss. I've contacted Fitbit who say I can return it - my cost for the return postage, though.
04-01-2016 11:58
04-01-2016 11:58
I just got off the phone with a tech with the same issue. Make sure your alta is on the base charging. Click the buton the the USB port to ensure it is charging. Restart your phone. Go to your settings. Bluetooth. Turn off your bluetooth for 30 seconds. Turn back on. Go to Wifi (if using it). Turn of wifi for 30 seconds. Turn back on. Go to app. Go through the set up process. It should work now. pay attention to the numbers on the screen after it connects. I hope this helps some!
