03-15-2016
14:51
18:43
03-15-2016
14:51
18:43
I got my Alta today and I've had it plugged in and charging for over 2 hours now and it won't turn on. If I tap the screen nothing happens, I've tried restarting it too. Any suggestions?
07-08-2016
12:32
09:32
AnnieFitbit
07-08-2016
12:32
09:32
AnnieFitbit
This was exactly what I needed to do to get my Alta to work. I was getting very discouraged as I just got it today and was thinking something was wrong with it. Thank you!
Moderator edit: Format.
07-12-2016
19:20
09:33
AnnieFitbit
07-12-2016
19:20
09:33
AnnieFitbit
I am having the same issues, and I have tried the reset (pushing the button on the charger 3x), I've set it up on my Laptop and phone, and the Alta says it is completely charged. When I tap the screen (after a few aggressive taps) while it is plugged in it shows me data, but when I take it off the charger I get nothing. I have tried tapping it all over the screen, on the side, etc. and nothing.
This is my first Fitbit and right now my first impression is pretty bad. I ordered this from Amazon, who do I need to contact about getting this fixed? Right now I am ready to call it quits and just return the Alta and not replace it.
Best Answer07-15-2016 13:37
07-15-2016 13:37
Thank you for this advice... I was getting mighty frustrated that my new device wouldn't turn on!
Best Answer07-15-2016 18:01
07-15-2016 18:01
Best Answer07-15-2016 18:05
07-15-2016 18:05
Best Answer07-17-2016 23:55
07-17-2016 23:55
Best Answer07-18-2016 03:25
07-18-2016 03:25
Best Answer07-18-2016 05:01
07-18-2016 05:01
Best Answer08-11-2016 16:33
08-11-2016 16:33
Best Answer10-09-2016 14:28
10-09-2016 14:28
Same thing here. I took it out of the box, tapping on the screen wouldn't do anything. Took out the charging cable, plugged it into my computer, nothing. Tapping on the screen, still nothing. Tried to set it up with my Fitbit app, the app cannot find the Fitbit Alta. I'm thinking I received a defective Fitbit Alta.
Best Answer10-09-2016 18:48
10-09-2016 18:48
Best Answer10-09-2016 22:02
10-09-2016 22:02
Best Answer10-23-2016 10:04
10-23-2016 10:04
Same thing is happening to me. I have an iphone 6
10-23-2016 10:05
10-23-2016 10:05
Same problems here.
Very frustrating.
11-16-2016 07:38
11-16-2016 07:38
My Alta will not turn on when I tap it twice and if it turns on when I turn my wrist, it will not go to the other screens when I tap it once. It turns off
01:20
09:34
AnnieFitbit
11-17-2016
01:20
09:34
AnnieFitbit
Did your problem got solved? I tried everything but my Alta is still not turning on. Brand new in box, I tried to sync it to the app, because I have an existing Flex. It tried to sync at first then stopped then it just stopped working. Blank screen, won't turn on, won't charge. Nothing.
This is the worst Fitbit ever. I regret buying it.
11-17-2016 04:45
11-17-2016 04:45
I contacted Fitbit and they sent me a replacement for my defective Alta. I recommend contacting Fitbit.
Best Answer11-17-2016 06:32
11-17-2016 06:32
It seems to be working better now. I have never restarted it. I have no idea how to do anything on the settings yet.
Best Answer11-17-2016 07:17
11-17-2016 07:17
Best Answer11-17-2016 12:02
11-17-2016 12:02
I'm on my second replacement and customer service treated me, as if I was trying to get over on them. I purchased mine from Macy's in May for myself for Mother's Day. It quit on me on Saturday, August 27th and now today, Thursday, November 17th. So disappointed. It's early in the day and my steps are not being calculated. I have to dig out the old flex until I can get this resolved.
