03-15-2016 14:51 - last edited on 08-20-2020 18:43 by MatthewFitbit
I got my Alta today and I've had it plugged in and charging for over 2 hours now and it won't turn on. If I tap the screen nothing happens, I've tried restarting it too. Any suggestions?
11-21-2016 09:45
11-21-2016 09:45
Hello everyone! I'm happy to see new faces around the Community!
I'm glad to see some of you have sorted out your issues after contacting support. Keep up with the stepping! Also, thanks to @Julia_G for her participation and help!
For the ones who are having issues with their Alta not turning on, my best recommendation is to restart your tracker. To restart your tracker, please plug it to a computer with the charging cable, and press the button of the charging cable 3 times within 8 seconds, waiting 1 second per press. After the last press, wait a few seconds and you will see the Fitbit logo for showing it's restarting.
As for the ones having syncing or set up issues, you can refer to the tips my good friend @HelenaFitbit provides in her post. Those steps work for both syncing and set up issues.
Last but not least, if you keep having issues with your Alta, please contact our Customer Support team, and they will gladly assist you further.
Keep me posted if you have any further questions!
Was my answer helpful? Awesome! Let's help our fellow Fitbitters by marking this as a solution, and vote up! 😄
11-30-2016 11:20
11-30-2016 11:20
12-01-2016 04:30
12-01-2016 04:30
That's amazing @TeamDJSAL! I'm very happy to see your Alta is working again!
If you have time please check our Discussions board, where you will find other members sharing their experiences and tips for an active lifestyle! Happy stepping!
12-01-2016 08:19
12-01-2016 08:19
Exact same thing happened to me. Customer service couldnt solve my problem so now I'm waiting for a replacement
12-02-2016 04:25
12-02-2016 04:25
Welcome to the forums @knut2650! Thank you for sharing your experience.
I'm glad to see Customer Service replaced your tracker. I hope you enjoy your new tracker!
By the way, if you have time please check our Discussions board, where you will find other members sharing their experiences and tips for an active lifestyle.
See you around! 😄
12-13-2016 19:14 - edited 12-13-2016 19:24
Three button press doesn't work for me. Just got a new Alta, wouldn't connect at first till I restarted it. Finally got it connected and ran the first update from my computer which resulted in an error. Screen is now off and won't turn on. Tried three button press several times, no response from device... Screen is still off.
It's more irritating that people have been having these issues for 8 months and the only solution is order a replacement for a 1 day old device. Should have done my research before buying.
12-14-2016 07:10
12-14-2016 07:10
I'm happy to see you have joined us in the Community @Rachel810!
I'm sorry for the issues you've been experiencing with your Alta, but thank you for reporting this to us and providing us with your feedback!
In this case, since you have tried the restart, I'd recommend contacting our Customer Support and explaining the situation to them. They will gladly look further into this and provide you with the best solution for this.
Catch you later!
12-24-2016 14:46
12-24-2016 14:46
I can't get anything on the display screen not even the battery charge picture. Ive tried plugging it into the computer and alos through a charger into a power point, still nothing. Please advise this is very frustrating as it a xmas present for my son.
12-25-2016 11:19 - edited 12-25-2016 11:20
This is crazy. Just gave one to my partner for christmas and it bricked in the setup process. A few minutes turned into 10 then 20 then 30 then an hour and nothing. Nothing in the help forum works. Alta is not recognized by the iphone or mac app anymore, Alta will not turn on, Alta will not respond to restarting via the charge cable button. Ugg. Merry Christmas.
12-25-2016 15:10
12-25-2016 15:10
No point im pushing the button if the dam screen remains blank, these fitbits are poor build quality and poor software release quality. Mine is going back and i will be getting a Garmin, at least it works... Sort out your QA fitbit this is crap.
12-26-2016 06:15
12-26-2016 06:15
Thank you for joining @anotherone99 @altauserpdx @hoges1122! Hope you're doing great.
@hoges1122 In your case, my best recommendation is to restart your tracker 2-3 times. It worked out for me! @altauserpdx, you can also try the restart a couple more times. To restart your tracker, please plug it to a computer with the charging cable, and press the button of the charging cable 3 times within 8 seconds, waiting 1 second per press. After the last press, wait a few seconds and you will see the Fitbit logo for showing it's restarting.
Additionally, please make sure that the contacts of the charging cable make proper contact with the contacts of the Alta.
@anotherone99 restarting the tracker when it's unresponsive can actually help the tracker to respond and start charging properly. I'd recommend trying it out, to see if it responds. Also, thank you very much for your feedback!
If any of you keep having issues after restarting, my best recommendation is to get in touch with Customer Support, and they will gladly assist you further.
I'll be around in case you need anything else!
12-26-2016 10:51
12-26-2016 10:51
Tried customer service and it was no help. They told me to try the same thing as found here, which is to push the button three times. Still not working and screen is still all black. Guess I'll trek back to best buy and try a new one. For anyone else trying finding this thread. Try the reset, but if it doesn't work, don't even waste your time diagnosing or calling customer support. Just return or exchange it.
12-28-2016 09:14
12-28-2016 09:14
Thank you for sharing your experience @altauserpdx. Hope you can get your tracker exchanged! it would be great to have you back on track! 😄
By the way, we have a Discussion Board available, where other users share their experiences and their tips for staying healthy. Go check it out!
I'll be around!
12-29-2016 13:48
12-29-2016 13:48
I have to say having owned other brands, i think this the Fitbit software is garbage and they should fire their engineering and QA teams letting this thing get out the door with it being reported with so many problems.
I've done all posted in this thread and the Alta won't come to life. I also love how the customer support team said an engineer would get back to me in 3 days...what a product!
01-02-2017 06:40
01-02-2017 06:40
Thank you for joining us in this thread @mshep44646! I apologize for the situation encountered with your Fitbit Alta.
I appreciate your feedback in regards this situation, and I'll make sure to pass it along to our team. Since you have tried all the steps in this thread with no success, my best recommendation is to wait for the reply from Customer Service. I'm certain they will provide you with the best solution, and they will continue to assist you, in case it doesn't work.
Let me know if you need anything else!
01-03-2017 10:59
01-03-2017 10:59
My daughters Alta charging cord does not even have a button, How do I reset it without that?
01-03-2017 11:06
01-03-2017 11:06
Hi, @cs2445, the button on the charging cable should be on the section that plugs in to the computer.
Some third party sellers provide a cheaper charging cable without a button. In that case you cannot reset the Alta.
You can purchase a genuine Fitbit charger from the Fitbit store. There is a link at the top of the page.
01-06-2017 06:48
01-06-2017 06:48
Glad to see you have joined us @cs2445!
As my friend @Julia_G kindly explained, the button is at the end that goes plugged into the computer:
Also, please note that the official Fitbit accessories and charging cables are only sold at Fitbit.com. If you find an accessory at a retailer, even if it's authorized retailer, it is a third party and, as per Julia's explanation, it would be missing the button.
01-06-2017 09:36
01-06-2017 09:36
I have the same problem! It was on at 4:30 this morning and suddenly no amount of tapping, jumping or anything will make it turn on. And yes - it is charged! Any help out there?
01-13-2017 01:36
01-13-2017 01:36
Thank you! This process worked for me after 3 hours of trying!
