03-15-2016
14:51
18:43
03-15-2016
14:51
18:43
I got my Alta today and I've had it plugged in and charging for over 2 hours now and it won't turn on. If I tap the screen nothing happens, I've tried restarting it too. Any suggestions?
01-13-2017 07:45
01-13-2017 07:45
Best Answer01-16-2017 15:07
01-16-2017 15:07
I have the same problem already reported here. My brand new fitbit stayed 2 hours updating for the first use, the mobile said it would take around 10 minutes. Now nothing happens.. fitbit should make a recall of Alta as this is a major issue. Everyone is having the same problem..
Best Answer01-18-2017 18:14
01-18-2017 18:14
same problem here-charged my fitbit Alta, said to do the fitbit/setup. did the setup and the screen went blank. customer care said to push the round button on the usb 3x in succession within 8 seconds, which I did, but it still will not power on. I know that the usb part is connected to the back as I even broke out my Loupes to make sure they were connecting.
Best Answer01-18-2017 18:18
01-18-2017 18:18
My fitbit is not paired to either my phone or computer yet. I have it plugged into the computer but the screen is totally blank. I've tried pushing the button on the USB charger but no luck so far.
Best Answer01-18-2017 18:58
01-18-2017 18:58
The fitbit support team sent me a prepaid label and told me that they would send me a new if I returned it. They said it would take about 6 days after it was returned. I said forget it and returned it for a Garmin. It took about 5 minutes to configure and works great. Also, my son has had an Alta for about a year and it now has this same problem. Junk!
Best Answer01-20-2017 20:28
01-20-2017 20:28
Has anyone figured out how to get off the Fitbit.com/setup part ? That's all that pops up on my screen when I tap it
Best Answer02-06-2017 17:44
02-06-2017 17:44
My fitback will not turn on using my iPhone or computer. It just stayed blank . I thought it was the charger fault but it was tested at a shop & showed that the watch is not working. This is a door gift & I do not know how to get a replacement or make it work. Any suggestions?
Best Answer02-07-2017 10:54
02-07-2017 10:54
Hi, @Soh12345, the best thing to do is get in touch with Fitbit Customer Support at contact.fitbit.com. Let them know what issues you are having and what troubleshooting steps you have already tried, Also be sure to tell them that it was a gift.
They will be able to look into this and advise you.
02-07-2017 19:11
02-07-2017 19:11
Thanks. Wrote to Fitbit. Waiting for reply
Best Answer02-14-2017 01:43
02-14-2017 01:43
Same problem here
it worked when it was charging after that went blank nothing happened if touched
i tried charging it over night and nothing happened the next day. I tried the computer and it didn't respond also I tried to reset but the Fitbit would not light up
pls reply on how to help
Best Answer02-15-2017 02:18
02-15-2017 02:18
I just bought my Fitbit Alta this afternoon. I have been trying to set up for the past 3 hours but there is no sign of charging ! I tried the tapping and the pushing the button on the USB cable but it's just not working! I had a flex for nearly 2 years and I did not have any problems until recently when the battery already dead !
Best Answer02-15-2017 21:49
02-15-2017 21:49
I received the alta today, charged it etc., will not turn on. Hate it!
02-18-2017 14:46
02-18-2017 14:46
Just bought my wife an Alta for her birthday to replace worn out Flex.
Pairing with phone failed, now black screen on the alta.
Won't pair with computer, won't turn on, button on USB cable does nothing.
What a load of rubbish! And some frustrating birthday present.
It's going back to Amazon for a refund, going to get a garmin or something.
Best Answer03-05-2017 07:40
03-05-2017 07:40
Over a year later, still having these problems. Just bought an alta for my son for his b-day. While in the update mode, the alta went black and wont turn back on. Both my wife and I work in tech fields and are capable for problem shooting these sorts of issues. Unfortunately, this alta is trash and will be returned to the store. Gonna have to go with a Garmin or different variety.
Best Answer03-18-2017 07:11
03-18-2017 07:11
Hey, is the Alta working now? I got a new one and screen went blank after charging for a while. Later after 5 hours its still blank and nothing is working out when I tried doing the reset steps. Any help here?
Best Answer03-18-2017 13:43
03-18-2017 13:43
Best Answer03-21-2017 08:54
03-21-2017 08:54
Hi all,
I've been reading through this thread because I had similar issues with my BRAND NEW ALTA. I wanted to post a recent update since this has been an ongoing issue since last year....
Anyway, I received it as a gift yesterday
and I charged it using my computer right after unboxing it. It charged all the way to full and worked perfectly fine when it was plugged into the computer and charging but as soon as I took it off the charger it became unresponsive (tapping will not turn it on).
I tried all the SOLUTIONS on this theard:
I finally broke down and decided to contact FitBit. I called them and they told me everything I already knew/tried (I just played along for their sake). The guy on the phone finally "determined" it was Battery Short Life. But I also had a Live Chat going with customer service, trying to figure out the root of the problem.The representative on Live Chat claimed it was a firmware update and that "the engineers are aware of this and are working to fix it" (I will post the transcript at the bottom).
My question is how do they let these products out the door if they do not even work brand new? And why are so many people having the same issue, yet FitBit has not released any official information regarding the problem. I've had mine for less than 24 hrs and didn't even get one use out of it, I don't know how some of you have the patience to wait weeks to resolve this issue because I definitely could not do that
lol.
I work in the tech field and I troubleshoot a lot so trust me when I say I tried EVERYTHING. Looks like the only solution to this problem is to request a replacement. Hopes this provides some insight and saves some time for other customers out there! Good Luck!... You'll need it lol.
Live Chat Transcript:
Ela (3/21/2017, 11:09:05 AM): Hi Michael, my name is Ela. How can I help you?
Me (3/21/2017, 11:09:33 AM): Hi
Ela (3/21/2017, 11:09:41 AM): Hello, Michael!
Me (3/21/2017, 11:09:43 AM): I called customer service already
Ela (3/21/2017, 11:09:57 AM): Oh, I see. Was the issue got resolved?
Me (3/21/2017, 11:10:49 AM): Kinda. I may have to get a replacement. I've been reading the forums and it looks like other people are having the same issue. Do you know why?
Ela (3/21/2017, 11:11:26 AM): That is great to know. I can also confirmed that here that you the previous advocate already sent you the email for the replacement options.
Me (3/21/2017, 11:11:42 AM): Seems like there are lots of faulty devices right out of the box.
Ela (3/21/2017, 11:12:29 AM): With the issue on your Alta, base on the information you've provided. To be honest, we do received similar reports just like what you've experienced with your Alta.
Ela (3/21/2017, 11:13:08 AM): But this one's different since I can see here that your Alta have an updated firmware.
Ela (3/21/2017, 11:13:43 AM): Most of the issue occurs when performing an update and our engineers are actually aware of the issue right now.
Me (3/21/2017, 11:14:03 AM): Oh ok, that makes sense.
Ela (3/21/2017, 11:14:03 AM): I sincerely apologize for the inconvenience, Michael.
Me (3/21/2017, 11:14:38 AM): They should put that on the forum somewhere so that customers are aware of this.
Me (3/21/2017, 11:14:56 AM): But thank you for clarifying
Ela (3/21/2017, 11:15:12 AM): Oh, sorry, just to clarify this. The issue I've mentioned is the issue about updating the tracker's firmware.
Ela (3/21/2017, 11:15:38 AM): But no worries, I will take note of your case and submit it so our engineers can also check this specific issue.
Ela (3/21/2017, 11:16:16 AM): I appreciate as well that you've let us know about this and once again, my sincere apology for the great inconvenience, Michael.
Me (3/21/2017, 11:16:33 AM): No worries.
Ela (3/21/2017, 11:16:55 AM): Thank you! I really hope that with your replacement Alta, the issue will not occur and so you can go and achieve your goal with us.
Best Answer03-27-2017 03:43
03-27-2017 03:43
Hi I got a Fitbit Alta for Mother's Day and I used to have a Fitbit 2. I deleted the Fitbit 2 and installed the Alta. I went through all the process of installing it and it gave me a 4 digit code which I entered. It then said searching and it might take up to 10 mins but nothing happening after an hour and my Fitbit won't turn on now.
Best Answer04-01-2017 06:19
04-01-2017 06:19
this worked for me! thanks so much!
Best Answer04-10-2017 04:05
04-10-2017 04:05
I have the same issue. This is my first time on this site as well. How do I get an answer?
