10-20-2022
09:04
16:33
LizzyFitbit
10-20-2022
09:04
16:33
LizzyFitbit
My silent alarms stopped synching after the last upgrade. Each alarm says "Not Synced Yet", even though everything else is synching fine. Any ideas?
03-14-2023
10:14
12:58
03-14-2023
10:14
12:58
Hi everyone!
I wanted to let you know that our team released the Fitbit app 3.77 version which brings a fix for issues experienced with the alarms. This update should be available for all our members, so please make sure to install it on your phone. For more details about how to manage your alarms, see this help article.
We appreciate your patience and we'll keep working to Fitbit more useful for you.
Best Answer10-20-2022 23:23
10-20-2022 23:23
Have the same problem. All my alarms started saying, “Not synced yet,” even when I let the sync process run for 10 minutes! Also some of my alarms duplicated themselves filling up all my alarm slots. Very annoying, but it seems that the alarms are in sync with my Alta because the next alarm is listed on the Alta… Fingers crossed that alarm goes off!
10-21-2022 07:34
10-21-2022 07:34
I had duplicates too but was able to delete them. My alarm was listed on my fitbit this morning but it never went off. Everything in my app still showing Not Synched.
10-22-2022 12:02
10-22-2022 12:02
I am also having this problem…have you had any advice on how to fix the issue?
10-22-2022 16:45
10-22-2022 16:45
Sorry, no. Hoping that an admin type or someone working for Fitbit will see this during upcoming week and offer suggestions.
10-22-2022 17:00
10-22-2022 17:00
I still have one alarm I can’t delete. And that’s odd that it didn’t go off. Are the alarms updating on the Alta?
Here are some of the things I’ve done:
10-22-2022 17:04
10-22-2022 17:04
Please look at my suggestions for cuch2 above. Maybe they’ll improve things for you. Is everything else synching okay for you? For me, everything seems to sync from app to device and vice versa but the app’s alarm page makes it seem like the alarms are not synched. But the alarms are synched and my Alta buzzes at right times for each.
10-22-2022 18:21 - edited 10-22-2022 18:23
I have rebooted phone and did a hard reset on my Alta. Problem persists. Alarms still show not synced in App. Only active alarm shows on my Alta but did NOT buzz yesterday morning. Next set to go off on Monday. Doubt it will go off but who knows. STarted after my last app store update. Next step is to reinstall the app. It will not let me toggle any of my alarms on or off. The slider bar is greyed out but with color if that makes sense.
10-23-2022 02:18 - edited 10-23-2022 09:45
I have tried all these but still have the problem. My alarms have been going off but I’m now on a weeks holiday so wanted to turn them off - which I can’t do by toggling them off, however I have been able to delete them.
I have contacted FitBit and they have suggested that the 3.69 update should fix the issue. My last update was 3.68.1…so I am awaiting the next update with anticipation 🤞🏻
10-23-2022 11:22
10-23-2022 11:22
This morning, I still could not update my alarms via app. I deleted them all and as I was re-creating them, the app would create a duplicate entry, making it impossible for me to recreate more than four 😐
But then I saw a suggestion to manage the alarms in the Web version of the Fitbit app, and that was more successful. I know you can toggle off an alarm from the Web version.
Here are the steps if you want to try:
Note that the Not Synced Yet message will continue in app (both Web and mobile versions) until the app developers fix it. Hopefully soon and not months from now!
10-23-2022 11:24
10-23-2022 11:24
Please see my reply to Vanillafairycak. Hope it helps
Best Answer10-24-2022 03:47
10-24-2022 03:47
I'm still showing Not Synched Yet, but a least my alarm went off this morning lol
10-24-2022 12:06
10-24-2022 12:06
Tried everything above - including restarting my Fitbit by plugging in USB, pressing button three times - restarted fine but didn't fix the problem. So, just spent 45 minutes in chat with Customer Support and as has been said, this is not going to get sorted until they produce an update which is very frustrating when we have come to rely on our alarms!!
Customer Service did advise "it is indeed something that is being presented in the first Fitbit devices" so I guess next they are going to withdraw support for older devices to make us buy new ones 😞
Best Answer10-24-2022 12:08
10-24-2022 12:08
My alarms won't go off!
10-24-2022 12:52
10-24-2022 12:52
Just downloaded the 3.69 update and it didn’t fix the issue. It was available in the app store.
10-24-2022 16:00
10-24-2022 16:00
Best Answer10-24-2022 16:00
10-24-2022 16:00
Me too - didn’t work!
Best Answer10-25-2022 02:14
10-25-2022 02:14
The update didn’t solve it 😔
Best Answer10-28-2022 14:57
10-28-2022 14:57
I’m on 3.69 and the problem persists
I find it all works fine and alarms sync to the device and go off okay - except occasionally, you get an alarm that won’t delete. These ones won’t sync to the Alta. I ignore them and eventually they go away. Possibly when I close the app or possibly when I’ve been trouble shooting and deleted the device from the app.
10-28-2022 16:07
10-28-2022 16:07
I have tried literally everything and nothing works - it’s so frustrating- I’ve downloaded the update, removed the app, re-started my Fitbit, tried on my pc - ready to give up now 🤷:female_sign:🙆:female_sign:
