04-19-2021 13:06
04-19-2021 13:06
Hi!
My Fitbit Alta keeps dying on full charge and won’t turn back on until reconnected to the charger. Have tried resetting it and the issue persists.
04-21-2021 06:54
04-21-2021 06:54
I’ve been having the same problem. It works up to the point where the battery indicates it’s about 1/4 charged then it dies. I have to plug into the charger to “wake it up”. So a charge is only lasting about 2 days.
04-23-2021 17:55
04-23-2021 17:55
Same thing is happening to me.
04-25-2021 11:09
04-25-2021 11:09
Mine has been doing this too. Full charge used to last about a week. Over the past week it has shut off multiple times at 90% and I have to plug it in to wake up. Today it has died twice despite being fully charged this morning.
04-26-2021 02:18
04-26-2021 02:18
Bonjour,
Pareil pour moi, elle s'éteint systématiquement à 10000 pas et très souvent alors que la batterie est chargée (même aux 3/4). Peut-on changer la batterie ?
04-26-2021 10:57
04-26-2021 10:57
Hello,
I am here for the same reason. I synced up this morning and my battery level was half way. I tried syncing after 5 miles on treadmill only to find it had stop working after 575 steps today. Only way I can "wake" it is to put it in the charger.
The interesting thing is, it does not charge at a steady pace. It starts as if the battery is totally depleted but then within 5-10 minutes (charging as I write this) the Alta battery shows to be OVER HALF way charged.
I noticed before it seemed to report being fully charged after fifteen minutes or so.
I think the battery is the problem!
04-26-2021 12:04
04-26-2021 12:04
Absolutely. It’s really frustrating. I’ve managed to borrow a Fitbit from a friend (coincidentally another Alta!) until I can replace mine. I’m hoping the same thing doesn’t happen to my loaner Fitbit too!
04-26-2021 17:38
04-26-2021 17:38
This has been happening to me too within the past few weeks. I also find I need to sync it more frequently so the time reads correctly as well as charge it every other day. I no longer get a battery dying warning. When I put it on the charger it shows 3/4 charged. My original charger broke awhile back and now I use an off-brand charger. I don't think I can reset it. This is my 3rd FitBit (I had two Charges previously) and I just don't think they're built to last.
