04-06-2020
05:20
19:37
04-06-2020
05:20
19:37
My Alta hr not syncing and the clock is not appearing. I do the reset and it shows the battery level then the face gets stuck on www.fitbit.com/setup scroll.
This started with the alta having really short cylces after being fully charged. It would only hold a charge for less than 36 hours. Sometimes it would die overnight while I was sleeping. I'd go to bed at 40 to 60% but it would be dead when I woke up. I'd have to do the reset exercise a few times to get it going before I could recharge it
I have done ALL the suggestions including:
Cleaned the prongs and connectors
Changed charging outlets
Left charging for 2 hours
Left charging no more than 4 hours
Reset through charge cord
Attempted sync through app by pulling down home page - it says sync is complete but the data doesn't change
Attempted sync by going into app and pressing forced sync button- it cycles but doesn't change information leaving old information of last sync which is now 15 hours ago
Atte
Turned phone completely off and restarted
Removed and reapplied Fitbit app
Yes, the continuous sync switch is ON
Going to Fitbit. Com/setup does nothing but put me in a continuous loop of removing and replacing app,
So....not by choice it looks like I'm done with Fitbits
04-06-2020 05:27
04-06-2020 05:27
That "setup" message means that the Fitbit has somehow become disconnected from your account and it will do or show nothing else until it is reconnected by going through the setup process again.
On the main dashboard page of the app, select your profile image at the top left and then select "set up a device"
04-10-2020 00:27
04-10-2020 00:27
@Zorabean did you get this sorted in the end?
04-10-2020 06:07
04-10-2020 06:07
When I go to set up I get the message
"Whoa there, There's a Fitbit Alta HR connected to your account already. Are you setting up a new one?"
No. I don't want to set up a new one. The one I have connected is strangely still recording steps [hasn't recorded sleep since November 2019 before any other problems manifested]
I don't want to sever any dubious bond I have at the moment, no matter how tenuous.
And on top of that, I have absolutely no response from the Fitbit anymore. On Tuesday the screen went completely blank. None of the old ways to revive it work. I am not getting ANY response on the watch face. However, as I said above, it is still strangely counting my steps each day.
