01-25-2021 19:37
01-25-2021 19:37
My alta won't charge
01-26-2021 12:21
01-26-2021 12:21
@dstrobel60 push the reset button located near where the charging cable plugs into its power source for a couple of seconds 3 times within 8 seconds, this should reset things. If not, your battery is dead.
Best Answer01-26-2021 22:28
01-26-2021 22:28
Well duh, if it won't charge it's dead, this we already know. This support team does not answer anyone's questions about why the Alta HR trackers will not charge. Seems many people are having the same issue here.
Best Answer01-27-2021 06:49
01-27-2021 06:49
@PhoenixWarriorB duh, no. Until attempting to reset, it's unnecessary to assume the battery is dead. Vaguely blanketing all Alta HRs as not charging is a broad assumption Yes, several people have this issue and I've noticed the Altas, in general, are more prone to earlier than expected dead batteries. You're participating in the member-supported community forum. Outside of occasional moderation, Fitbit isn't monitoring conversations here, and if your goal is to reach them, you'd be better off contacting them through their support channels.
FWIW, I've got several Alta and AltaHR that people assumed dead. They just needed a reset.
