03-17-2017 14:48 - last edited on 08-20-2020 20:08 by MatthewFitbit
After collecting my new alta hr today I'm disappointed to find it won't connect to my Bluetooth. I have previously had a charge hr and flex and had no issues connecting either of these with initial set up. So far I have uninstalled and reinstalled the app, turned my phone off and on again, turned Bluetooth on and off again but no luck so far.
Does anyone have any suggestions? Thanks for any advice
05-20-2017 01:49
05-20-2017 01:49
@Ed_Public 😀very good point!
Helen | Western Australia
05-22-2017 22:32
05-22-2017 22:32
Have tried all suggestions and it won't link to my Bluetooth-I have reinstalled app, updated software on Apple phone, etc etc.....
05-23-2017 01:56
05-23-2017 01:56
@Debmcp If you have tried everything listed in this Help Article then you are probably best to contact Customer Support Let us know how you go.
05-24-2017 05:51
05-24-2017 05:51
I'm not familiar with Samsung, it sounds like you did what you needed to do, I will say this, I connect better with my IPad, if that helps.
06-29-2017 09:43
06-29-2017 09:43
So mine won't connect either. I have a Huawei P9 Lite, and was told today that this phone is not supported by the fitbit app.........by the fitbit support team.
Of course this makes NO SENSE as it's an android.
I have done everything I can including switching off every single Bluetooth enabled device in my house. I cannot control what moves past my house though.
What I do not understand is that the phone picks up the fact that my tracker is there........it finds it. And then it just sits there and does not connect.
How is that even logical?
So back to fitbit..........please get us online without all this drama.
06-29-2017 10:07
06-29-2017 10:07
@AntsJordaan Ok, first of all it is a pain that your phone is not compatable with the fitbit app and I understand your frustration. But I dont really understand what you are saying. Support have told you that it isnt compatable. If you would like to check yourself, here is the link. Compatable Devices The fact that it is not compatable doesnt mean it wont partially work (yours recognises your tracker so it does some of what it is supposed to) but that isnt much use to you. The fact that it is an android phone is irrelevant. If it isnt on the list chances are it wont work as it should. Do you have a tablet or a laptop you can use to sync to the app? If not, it sounds as if it is not going to work for you.
06-30-2017 01:52
06-30-2017 01:52
Hi, nelly. I assumed that the system dictates compatability. I mean, when we have Windows on a laptop, they don't say it's not compatible to an HP, but is to a Lenovo? That's the logic I was going with. If the phone has Android, it should work.
But I guess it's different for phones then and my logic was too basic. 😄
Thanks though.
06-30-2017 14:27
06-30-2017 14:27
1 hr in. Ready to throw it across the room. I never had this problem with either of my altas.
06-30-2017 14:35
06-30-2017 14:35
07-01-2017 12:39
07-01-2017 12:39
Hey. Good on you you were able to connect with ur bluetooth! Mine stopped connecting! Initially it was fine but now it's updating. Help! Share whatever u have done to synchronize it again. Many thanks!
07-01-2017 13:05
07-01-2017 13:05
07-12-2017 08:38
07-12-2017 08:38
Had the same problem but found a fix... turn off the wifi in your phone and it will pair.. just did that and it worked perfectly.
07-12-2017 10:20
07-12-2017 10:20
08-07-2017 21:15
08-07-2017 21:15
Mine is brand new, o e day old and not synching to my phone. It did not come with a dongle so I have no idea how to get data off it.
I do not have two rooms three hours to play with it so tell me what to do so I can get it to synching.
08-07-2017 22:50
08-07-2017 22:50
08-08-2017 06:06
08-08-2017 06:06
08-08-2017 07:48
08-08-2017 07:48
08-08-2017 15:48
08-08-2017 15:48
08-08-2017 15:54
08-08-2017 15:54
08-10-2017 01:45
08-10-2017 01:45
I have followed all of these instructions and my Fitbit Alta HR still won't connect to my phone. I've logged out of the app, deleted it, re-downloaded it, turned off bluetooth, restarted my phone, turned bluetooth back on! Very frustrating! It also isn't classing active minutes as "daily exercise"
HELP!
