Alta is not responding to anything
I just recieved my Alta, Its been fully charged and is not responding to taps and the screen is black, nothing. I did the button thing on the charger and nothing. Any suggestions would be appreciated.  Thank you.
3 REPLIES 3
Hi @Quinn5150  the Alta series was discontinued about three or four years ago, so it could be your Alta has a battery that is dying. Can you return it to the seller?
Stepping in the U.S.A. since September 2013. Android 14
Support said mine was still under warranty. So they are sending a
replacement.
Thanks for your response.
@Quinn5150  that is wonderful news. When the replacement arrives, set it up as a new device on your existing account. That way, your history will be there and you can continue the journey.
