05-25-2021 03:02
05-25-2021 03:02
Hi, can anyone help? My Fitbit Alta charges fine and works whilst on change, but as soon as I take it off of the charger, screen goes blank and won't turn back on. Has my Alta completely given up or can I fix this?
06-05-2021 10:30
06-05-2021 10:30
This is happening on mine too. Hadn't used it in over a year. It charges fine, the display works while attached to the charger, but when disconnected from the charger, the display no longer works. Any fix solutions would be appreciated.
06-12-2021 02:32
06-12-2021 02:32
This also happens to my Alta.
06-12-2021 03:10
06-12-2021 03:10
This has just started happening with mine this week - started turning off when wearing on Wednesday (fully charged) and now turns off as soon as I take it from the charge. Re-booted numerous times but that won't fix it.
06-12-2021 09:49
06-12-2021 09:49
I am having the same issue.
06-12-2021 14:55
06-12-2021 14:55
Same here! It works as long as it's charging, Take it off and it goes blank
06-15-2021 13:57
06-15-2021 13:59
06-15-2021 13:59
Mine just started doing the exact same thing! Strange everyone is having the same problem at the same time isn’t it?
06-16-2021 12:08
06-16-2021 12:08
Anyone have a solution yet?
06-18-2021 05:41
06-18-2021 05:41
Mine is doing this too!!
