09-06-2017
15:42
18:17
09-06-2017
15:42
18:17
The screen brightness on my Alta is very dim and unreadable in all but the lowest light. I have tried to reset the device but it has made no difference. Can anyone help?
Thanks.
07-13-2021 08:25
07-13-2021 08:25
im having the same problem .my alta used to work well for 2 years or so now its too dim to see when outside can anyone suggest any solution for this
08-10-2021 15:07
08-10-2021 15:07
My Fitbit Alta HR has the same problem with dimness (since I first wore it). I have put up with it as it was a gift but what can be done?
08-10-2021 22:41
08-10-2021 22:41
09-22-2021 06:06
09-22-2021 06:06
You’ll have to buy a new one. The guarantee is of date or speak to customer services
09-22-2021 06:07
09-22-2021 06:07
I agree with you. If it’s out of guarantee. Tell customer services you are dissatisfied with the service. They sent me a new one FOC
05-02-2022 00:42
05-02-2022 00:42
Me too. Have read all the posts about screen brightness on a fit bit Alta. None of the resets work. I have had my fit bit a couple of years -
donthey just wear out? I cannot read the screen unless the room is dark!!
05-02-2022 01:22
05-02-2022 01:22
05-02-2022 02:04
05-02-2022 02:04
