09-06-2021
01:03
18:17
09-06-2021
01:03
18:17
I charged my alta battery full. A code keeps appearing on the display v21 40 02....just wondered if anyone knows what it means please 🙏 heeeellllpppp
The dashboard display works when it's on charge buy when I take off of charge the screen stays blank.
09-06-2021 09:44
09-06-2021 09:44
Hi @Halochic the Fitbit version is on the screen when you do a restart, so that is what you're seeing and it's perfectly normal. Now, as to the screen being blank when you take it off the charger, does it respond to any taps or movement and does the app show any steps being accumulated?
09-06-2021 09:57
09-06-2021 09:57
09-06-2021 10:22
09-06-2021 10:22
@Halochic try restarting it a few times? You need the original charger with the button on it to do that. If restarting doesn't jolt it awake, then it might just be the end of life for your Fitbit.
