03-22-2016
15:07
18:43
03-22-2016
15:07
18:43
10-19-2018 20:30
10-19-2018 20:30
How do you check the firmware? My Alta is shutting down on me... First, it was a battery then, now they say it is a firmware issue. How can I get the error code? It is out of warranty, but I haven't used it for 8 months, so I thought it was a battery. Now they say it is a display problem?
Do anyone know how to access error codes? I got the 25% discount, but seriously don't want to make another investment and get disappointed.
11:40
11:11
10-25-2018
11:40
11:11
Good to see you in the Forums guys! 🙂
@riffox, I checked with the Support Team and it seems they've already got in touch with tyou.
@schin88, unfortunately, if this is what our Support Team has already offered, there's not much else I can do from my end 😕
Thanks a lot for your comprehension and anything else you may need, I'm always around!
01-06-2019 06:07
01-06-2019 06:07
The link at the "solution" https://community.fitbit.com/t5/Alta/Set-up-issues/m-p/1233890/highlight/true#M1293 no longer takes us to the solution!!! The problem hasn't gone away. Where can we find that solution now?
06:39
11:11
01-10-2019
06:39
11:11
@JimSTX Thank you for joining us in this thread! I would like to follow up on the issue that you are experiencing and would like to know more details about the issue. If your Alta is shutting off, my best advice is to restart your Alta as described in this help article. Make sure to select the process for the Alta tracker.
Once you've restarted your Alta, charge it for 3 hours and see if the issue gets fixed.
Let me know how it goes! ![]()
Best Answer03-19-2019 12:39 - edited 03-19-2019 12:40
I am having issues with my tracker shutting off constantly, so I followed your link to the article for restarting my device. I have followed the directions to restart my alta multiple times, but my tracker WILL NOT restart. It just buzzes every time I hit the button whether it's three times or thirty (seriously, I did it). The "battery" icon stays on the entire time. This is getting ridiculous.
Best Answer03-26-2019 23:22
03-26-2019 23:22
I recently started having the same problem. My Alta keeps shutting off even though the battery is not dead. I have done the reset solution as advised in this thread but it keeps happening. Is this just a money grab in order to be forced to purchase a new one at an offered discount?!
03-27-2019 10:55
03-27-2019 10:55
I am having the same issue! This is my SECOND Alta to seemingly crash both hardly lasting 2 years each. I am hoping there is another option to fix this issue or I may have to try a different brand of trackers. Its too bad because when my Alta is working I really love it
Best Answer04-17-2019 10:32
04-17-2019 10:32
Both Alta’s I have purchased are doing the same thing. I thought the first just needed to be replaced as it was a couple of years old. Now the new one shuts off randomly even with a full charge. I carry the charger with me to turn it back on, but it is frustrating to lose all those steps before noticing that it’s off. I have followed the restart instructions numerous times to no avail. Please fix this in a software update or something!
Best Answer04-17-2019 18:59
04-17-2019 18:59
Mine is also shutting off. I have to plug it in to turn in back on. But, when I do that it shows the incorrect time. My battery is perfectly fine. Whenever I plug it in to turn on, it is mostly full or full. I hope you can help.
Best Answer04-18-2019 01:03
04-18-2019 01:03
04-19-2019 06:42
04-19-2019 06:42
My Alta is doing the same thing. I have to juice it up and it starts again ... I went to bed and Alta was fine ... the next morning I went for my walk and darn if it didn’t shut down again. I lost all my steps. It’s doing it all to often lately! Yes battery fully charged!
06-09-2019
15:10
04:13
JuanJoFitbit
06-09-2019
15:10
04:13
JuanJoFitbit
I totally agree about throwing it away! I've had fitbit products since almost the first one developed. Until this alta I've been happy. Now I'm ready to change brands. Don't know what else to do. This is my 2nd Alta and didn't even last 8 months and just keeps dying even with full battery. Reset, start again. Middle of a run, stops. Very disappointing! And extremely frustrating. Anyone know an actual solution?
Did you ever get a working solution? I've tried connecting to your instructions and can't seem to find them.
Moderator edit: merged reply
07-14-2019 03:32
07-14-2019 03:32
Well CrapTurds. I came here hoping to find a solution. I am on my second as well. They sent a replacement for the first, after I declined the 25% off offer towards a new tracker when mine failed one month out of warranty. This replacement started doing the exact same thing at the exact same time...one month past the year warranty. Lol
I am trying to decide on a new brand right now. It really makes me so sad. I'm totally disappointed.
Best Answer07-14-2019 16:37
07-14-2019 16:37
Best Answer07-15-2019 00:17
07-15-2019 00:17
Best Answer07-17-2019 21:59
07-17-2019 21:59
I've bought ionic after my both altas.
Ionic died exactly one year later. Killed by update probably.
Fortunately I've got warranty with mistaken month and was able to return it to the shop. They couldn't replace it with ionic but offered Versa and returned price difference.
Versa is generally ok but it's HR sensor is terrible. I've got only few nights with detailed sleep for last month. It constantly says that it can't read continuous heart read.
My next tracker will be definitely not Fitbit.
Best Answer07-29-2019 22:58
07-29-2019 22:58
My wife's fitbit Alta has the same issue, it shuts down randomly and then as soon as I connect the charger, for a second reboots and shows that the battery is actually fully charged.
Best Answer07-31-2019 12:29
07-31-2019 12:29
Best Answer07-31-2019 22:58
07-31-2019 22:58
I think You are wrong!
They have seen what happened and they did something! Now Ionic tracker dies just few day after warranty period too! 🙂 I think all trackers will act the same now. It so fun to push people to order trackers every year! 🙂
08-05-2019 04:30
08-05-2019 04:30
Yeah, mine has been doing this for a while now. Of course, I'm out of warranty because it was a replacement of a replacement, if that makes sense. I've just been dealing with it while I research other brands. I considered buying a Charge 3, but at this point, I just don't have faith in the Fitbit brand anymore. It's infuriating to know this has been an issue for these trackers for years and they just don't care.
