01-13-2021 14:48 - last edited on 01-17-2021 13:20 by AlejandraFitbit
Fitbit Alta stops working even though it’s 75% charged. I charge it to 100% and as soon as it gets to 75% it stops working.
01-17-2021 13:21
01-17-2021 13:21
Welcome to the Community, @M1-.
Have you tried to restart your device? If you haven't, I recommend trying this by following the steps in the help article: How do I restart my Fitbit device?.
Let me know the outcome.
01-17-2021 13:21
01-17-2021 13:21
01-25-2021 08:19
01-25-2021 08:19
I have tried restarting several times and it will not restart to the welcome message. However problem still exists it stops working when battery is 75% charged and is dead until you connect to the charger. Very frustrating. Can you please help.
01-29-2021 23:14
01-29-2021 23:14
My fitbit stopped working after 2 years. The screen buzzes, then goes blank. Nothing works to restore it. It doesn't charge, NOTHING. But if I connect it to charge 4 days later it works again. BUT I lose all my data and time etc. Friends stopped to. Same age. I told her haul it out of cupboard andto try charging it. It charged. Both then die suddenly after about a week. But if I wait 4 days itll THEN charge. This seems like a preprogrammed malfunction to me.
Any advice as I can't use the device like this. I need my steps to count!
02-10-2021 03:20
02-10-2021 03:20
I have similar issues. Cant resolve them at all very frustrating
02-10-2021 08:48
02-10-2021 08:48
Have you solved this issue yet? I have been trying to get this resolved on my Fitbit Alta as well. Thanks!
01-09-2023 07:26
01-09-2023 07:26
Hi.
I have the same issue in that my Fitbit stops working even though the battery is at 75%. I've tried rebooting it but it hasn't fixed it. What can I do?
02-19-2023 13:57
02-19-2023 13:57
I am having the same problem as SherKil & M-1. My Alta stops working once it gets to 75%. I have restarted several times but the problem still exists. Please advise how to fix
02-19-2023 14:11
02-19-2023 14:11
I am having the same problem as M1- & SherKil & others. My Alta stops working when it get to 75%. Per your suggestion, I have tried RESTARTING several times & the problem still exists. This is a brand new Alta, my 3rd since 2016 & I have never experienced this problem before. What can I do?
02-21-2023 11:31
02-21-2023 11:31
02-27-2023 11:53
02-27-2023 11:53
I am having the same issue as the posters above. My Fitbit is 87% charged and it just randomly stopped functioning. AGAIN. This has been going on for almost a year, although it's been worse lately. I have to have my charger with me at all times, in order to reset it. Very frustrating. I called Customer Service about this last week and they had no answers. Please help.
04-02-2023 16:22
04-02-2023 16:22
@SherKil @JulyMom2x @WendyBur I'm having the same issue as all of you... I suspect it could be the fitbit app or firmware.
Question for you all: what smartphone (and version of the os) are you using with your fitbit?
I use an iphone X on ios 14 and it seems like fitbit is only supporting ios15 onwards.
