09-05-2022
16:12
05:49
09-05-2022
16:12
05:49
I have the new Samsung Galaxy S22+ and Ican't get it to sync to my fitbit, it says an App is needed? I have deleted the fitbit app several times and its the same thing? I'm not get notices that I have text messages or phone calls on my fitbit. Worked fine on my old phone S10+ I have talked to Ftibit I got a new charger tried to reset the fitbit and nothing!!! I hope someone can help me.
09-05-2022 17:18
09-05-2022 17:18
Hello @Lavildsen
Hopefully I can help. I think trying to set up your Alta as a new device would be the best way to go about it. You will not lose any of your data setting your Alta up as a new device as your data is held with the the Fitbit Servers. However, you will lose any data you got “after” you last successful sync. That most likely occurred when you took it off your old phone.
Before you begin make sure (if you still have your old phone) that your not showing on your old phones Bluetooth. If it is please remove it from that Bluetooth.
Here is how you set up your Alta again as a new device. Please follow these instructions carefully and do not skip a step:
😃 I’m hoping this works and provides you with a solution. Please come back and let me know how it went.
