09-14-2020
11:04
14:49
AlejandraFitbit
09-14-2020
11:04
14:49
AlejandraFitbit
Is the Alta just built-in obsolescence? Mine is 20 months old and needs charging daily, I can't believe it is designed to fail quite so quickly? Any tips?
01-23-2021 14:50
01-23-2021 14:50
It's great to see you around, @Slinks.
If your tracker isn't holding a charge, I recommend taking a look at the help article: Can I extend my Fitbit device's battery life? and follow the tips provided there. After following them, test your unit.
Let me know the outcome.
