11-20-2021
21:15
11:46
11-20-2021
21:15
11:46
I'm getting notifications my battery is low AFTER the unit will no longer turn on. The weird part is the battery is usually showing half full. It charges up and synchs up fine, but the charge seems to run out faster than it should. Anyone else having issues? Any ideas? BTW, I still LOVE my Alta.
11-23-2021 11:48 - edited 11-23-2021 11:48
Hi there, @VickiB12. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Alta. I understand where your concern is coming from as you love your Alta.
If you haven't done so yet, I'd recommend following the troubleshooting steps provided here Can I extend my Fitbit device's battery life?
Hope that helps.
Best Answer11-23-2021 11:48 - edited 11-23-2021 11:48
Hope that helps.
