12-15-2020
17:44
12:39
12-15-2020
17:44
12:39
Fit bit alta does not sync to my new phone. Samsung s20 fe. Help
12-17-2020 12:44 - edited 10-06-2023 07:36
Hello there @Hoebel, welcome to the Community Forums.
Please follow the recommendation provided by @SteveH. Also, please make sure to follow these steps to successfully link your Alta to the new phone:
For more troubleshooting steps, please see: Why can't I set up my Fitbit device? and Why won't my Fitbit device sync?
Please know Fitbit products are compatible with most devices that have the following operating systems: Apple iOS 12.2 or higher, Android OS 7.0 or higher, and Windows 10 version 1607.0 or higher, see Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported and does not meet the require OS we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
We routinely test new devices to ensure full compatibility with Fitbit devices and the Fitbit app, and are constantly working to confirm compatibility with new phone models. Be sure to verify that your phone or tablet meets the minimum operating system requirements.
Best Answer12-16-2020 00:08
12-16-2020 00:08
Do you still have your old phone? If so, make sure it doesn’t still have a connection to the tracker in its bluetooth settings as this could be blocking connection to your new phone.
