06-19-2017
05:29
21:32
EstuardoFitbit
06-19-2017
05:29
21:32
EstuardoFitbit
I just got my Alta from a friend as a gift on June 17. It had been working perfectly until last night. It completely shut off. I plugged into charger and it became extremely hot. The next morning, it still won't come on unless I hook onto charger (battery shows full) so it's not dead. My charger was misplaced so I'm using a friends and there's no button to reset it. I literally have only owned it for 2 days! Somebody help.
06-19-2017 07:13
06-19-2017 07:13
Hello and welcome to the forums @GolfGirl1998
Unfortunately, there is no other way to restart your Alta without the original Fitbit charger unit. Since you just got the Alta, the charger must be somewhere in your home. See if you can find it?
How long did you have it on the charger unit? It's not recommended to leave it on all night.
You can learn more about restarting here - click
Let us know what happens.
06-19-2017 07:13
06-19-2017 07:13
10-17-2017 12:27
10-17-2017 12:27
Mine is doing the same thing
Best Answer10-17-2017 21:27
10-17-2017 21:27
@Melhammons15 what exactly is happening with your Fitbit?
If it's getting hot, get with customer support at this link - click There is a phone number for the USA, an online chat option and web based email for those out of the area.
10-18-2017 19:44
10-18-2017 19:44
Hi there im having the same issue with my fitbit. My original fitbit charger broke when my kids stood on it. So I had to purchase a new one. Unfortunately it's not a fitbit brand charge but it's very similar charger.
It has been charging well up until a few days ago where my watch does not turn on at all. The only way the watch will work is when it is plugged into the computer other than that it will not turn on at touch or any other way. I've had this watch since Dec 2016. Any advice on how to remedy thss issue as I would like to continue using my fitbit.
Best Answer10-18-2017 23:05
10-18-2017 23:05
@JMarino you need to do a restart of your Fitbit, which requires that you have an authentic Fitbit charger unit. You can buy one at a local retailer (Target, Staples, Walmart, Best Buy, etc) or directly from Fitbit.com
To learn how to restart your device, click here.
10-19-2017 02:04
10-19-2017 02:04
Hi there,
I have brought a fitbit charger with the start button and still unable to restart or use the fitbit. I have tried pushing the button 3 times but still no luck. I have tried several times within the last 2 hours but no luck. Any suggestions ??
Best Answer10-19-2017 08:04
10-19-2017 08:04
If you're within the one year warranty and it was purchased from an authorized retailer, contact customer support at this link - click
Keep us informed.
01-17-2019 00:05
01-17-2019 00:05
01-17-2019 06:20
01-17-2019 06:20
Hi @JMarino
Thanks for the update. I hope you and your husband are enjoying your devices.
08-28-2019 16:02
08-28-2019 16:02
I have the same problem, I restarted it but it does not help. What else can I do? Everyone I ask keeps telling me to restart it but it does not help.
08-28-2019 16:52
08-28-2019 16:52
Hi again @Skylar07
You using Android, too? Might be you need to restart it a few times and make sure your phone is compatible with the device. Let us know.
Best Answer01-10-2020 19:35
01-10-2020 19:35
I have the original charger, it is charged, it works when it is charging (giving me info and the screen works) as soon as I take it off charge it does not display.
I have tried to restart it about 7 times, to no effect
01-10-2020 20:14
01-10-2020 20:14
Hi @NZuser9 the quick view feature means you don't see the screen all the time. When you twist your wrist, you see it. Could this be the case for you?
Best Answer04-07-2020 05:48
04-07-2020 05:48
I have Fitbit Alta with the original charger, it is charged. It works when it is charging (giving me info and the screen works) but as soon as I take it off charge it does not display anything and wont turn on at all.
I have tried to restart it numerous times using the 3 button technique with no effect. Any ideas?
04-07-2020 05:49
04-07-2020 05:49
I am pretty sure the NZ person is having the same issue as me, it just will not turn on no matter what I try, its worked for several years well, then all of a sudden nothing.
04-07-2020 06:13
04-07-2020 06:13
Hi @Nazz0 sometimes these devices die. Try restarting it a few more times to see if you get any spark of life from it.My Blaze worked fine for about two years and one day it simply didn't respond to being charged or anything.
