01-10-2021
07:41
09:48
AlejandraFitbit
01-10-2021
07:41
09:48
AlejandraFitbit
I accidentally got some hot water on my Alta and it buzzed without stopping for about 5 minutes. I plugged it in and it showed the Fitbit logo and then a number but then turned off. The display isn’t working even after it was charging all night. Is there anything I can do or isn’t it just broken
01-11-2021
09:49
08:36
01-11-2021
09:49
08:36
Welcome to the Community, @Suzie13.
Thanks for troubleshooting this turning on issue. If your tracker isn't responding, I recommend restarting the unit by following the steps in the article: How do I restart my Fitbit device?.
Let me know how it goes.
Best Answer01-11-2021 11:15
01-11-2021 11:15
Thank you for helping. I tried restarting it a few times but it still will not work.
10:31
08:36
01-13-2021
10:31
08:36
Thanks for getting back, @Suzie13.
Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else.
