06-02-2022 20:04 - last edited on 06-03-2022 11:29 by MarreFitbit
Fitbit is charged. When I take it off the charger and put it on my wrist it won’t turn on. It only turns on if I plug it back I to the charger. Is there anything I can do y
06-03-2022 11:30 - edited 12-17-2023 04:34
Hi there, @Kansaskarla. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Alta.
As a first approach, I'd recommend restarting your Alta. For instructions, click here.
If the issue persists, please see Why isn't my Fitbit device's battery charging?
Hope that helps.
Hope that helps.
06-04-2022 08:18
06-04-2022 08:18
Me, too - I even tried leaving it on the charger overnight. I was thinking of a Versa, but this situation has knocked my confidence in the fitbit products.
06-06-2022 06:59 - edited 12-17-2023 04:33
Hello, @JSB123. Welcome on board. We‘re taking your comments and sentiments in regards to our products into consideration.
If you haven't done so yet, I suggest following the recommendations I provided here.
Hope that does the trick for you!
06-12-2022 10:38
06-12-2022 10:38
I tried the steps you had mentioned, it's still not turning on when is off charger. Does this mean it's end of life ?
06-13-2022 07:20 - edited 11-16-2023 02:30
@cadust Welcome on board. I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
