08-08-2022
15:41
17:35
08-08-2022
15:41
17:35
Hi,
I have a Alta, just restarted it and it only seems to turn on when connected to charger. It is fully charged but once disconnected from charger screen goes black after a few seconds and won’t turn on. I have also recently updated to the latest firmware v21.40.02. The connector has been cleaned as well. Any suggestions?
08-08-2022 17:36 - edited 11-20-2023 15:28
Hi there, @Lilgris. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Alta. I understand where your concern is coming from.
As a first approach, I'd recommend restarting your Alta. For instructions, click here.
If the issue persists, please see Why isn't my Fitbit device's battery charging?
Hope that helps.
08-10-2022 15:02
08-10-2022 15:02
This has happened to me too and I have restarted my Fitbit but it won’t work
08-15-2022 07:51
08-15-2022 07:51
I've had the same thing happen with my Fitbit Alta. Battery is full. Have recently updated the firmware. Yet it only works when plugged into the charger. Hope there is a way to fix this?
