04-26-2021 10:45
04-26-2021 10:45
My Alta wont hold a charge or turn on if unplugged. The screen only turns on when attached to the charging cable, once I unplug it dies . I see that many people have the same problem. I have called customer service waiting for an answer. I have tried everything they have suggested.
05-03-2021 19:02
05-03-2021 19:02
it sounds like it needs an new battery
Best Answer05-06-2021 09:01
05-06-2021 09:01
and how can you get a battery if the product is out of warranty?
Best Answer05-06-2021 12:58
05-06-2021 12:58
umm i just look online for fitbit alta batterys but there hard to get in in out have you been to the fitbit suppot
if not here is a link https://myhelp.fitbit.com/s/support?language=en_US then just do the one you think is best
Best Answer05-06-2021 13:00
05-06-2021 13:00
i have almost no details and they said to send it to the place and they will send me a new one
Best Answer05-07-2021 11:46
05-07-2021 11:46
I just chatted with support and they, hopefully, fixed my problem. I am using the original charger. I was told to plug it in and attach my Alta. Then to push the circular button on the USB end 3 times with a tiny pause between each. It appears to have worked and reset my fit bit. The Alta should vibrate, mine did not, and then show the logo. Hope this helps the rest of you.
