10-02-2016
04:20
18:17
10-02-2016
04:20
18:17
My Alta suddenly stopped working and now just has a battery symbol with an exclamation mark in the middle. Can anyone help?
11-27-2019 18:33
11-27-2019 18:33
None of this worked in mine so, had to get a new watch
14:40
07:47
11-29-2019
14:40
07:47
Hi @Rozemail. Welcome to the Forums. @Noahaman, it's good to see you here. I'm sorry for my delayed response.
@Rozemail, thanks for sharing the steps tried to get your Alta working again. @Noahaman, while the steps didn't work for you I'm glad that you were able to receive a new Fitbit. You both did a great job and I'm sure you'll continue reaching many goals!
In case you have some spare time, I’d like to invite you to visit our Discussion Board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted.
Catch you later.
Best Answer12-09-2019 12:26
12-09-2019 12:26
There is no button on the back of my charger
12-09-2019 13:41
12-09-2019 13:41
Mine is the Alta Fitbit. There is a black recessed button on the USB charge . With the Fitbit connected press the reset button 3 times real fast.
12-10-2019
16:15
07:47
12-10-2019
16:15
07:47
Hi @Dencuddy, welcome on board. @Mn3wt0n21, it's good to see you here again and thanks for your big help!
@Dencuddy, thanks for joining this thread and as our friend @Mn3wt0n21 mentioned the button is on the USB end of the charging cable. Please take a look to this picture shared by @wtksk8r and once you find it try restarting your Fitbit. If your tracker keeps showing a battery symbol on its screen, reply back to this thread so I can continue working on this with you.
Best Answer03-28-2020 08:45
03-28-2020 08:45
I have tried restarting my Fitbit Alta numerous times over the past few days, and it is still only showing the exclamation mark. Please help. Thank you!
03-28-2020 12:02
03-28-2020 12:02
Best Answer03-28-2020 12:37
03-28-2020 12:37
If you rapidly pressed the reset button then, stop it usually will start charging. You may have to press it several times.
Do it till it doesn't have the exclamation mark on the screen.
Best Answer03-29-2020 11:53
03-29-2020 11:53
Thank you both for taking the time to reply! I've tried both of these suggestions, neither is working to this point unfortunately.
Best Answer04-12-2020 06:31
04-12-2020 06:31
Mine did the same thing (along with the green lights being on bright and the display screen going black). I tried all of the troubleshooting ideas to no avail. It is 13 months old. I contacted support and they basically told me to purchase a new one with the 25% discount. They said the tracker should last longer than a year, but I must have had a defective one. Reading the support forums, I’m one of several with the same problem. I will not be purchasing another Fitbit as I have no desire to replace the device at my expense every year.
06-06-2020 21:19
06-06-2020 21:19
I have tried the trouble shooting and my device still has the exclamation mark
Best Answer09-02-2020 07:53
09-02-2020 07:53
I was having the same problem. Did the button press 3 times on my charger. It restarted but still just battery symbol with exclamation point. I almost gave up. I pressed the button over and over and over until my display finally popped up😀
Best Answer10-16-2020 14:28
10-16-2020 14:28
This happened to me. Unplug device. Use alcohol on quip to gently clean contact area on charger and Fitbit. Plug in charger to USB port. Attach your Fitbit and feel vibration. Look at battery. Bottom part of pic shows dots before exclamation appears. Disconnect Fitbit from charger and quickly reengage. Do this repeatedly (took me 10 times). It is to give enough trickle charge to start the battery again. The exclamation point disappears leaving the first battery bar present. Allow to charge. If this doesn’t work, the battery may be toast.
