05-24-2020
20:54
19:19
05-24-2020
20:54
19:19
I have had no issues with all my fitbits. This one in past week has began to drain the battery quickly. I have tried to restart 3x now. I have charged it fully and it dies quickly. Why is this happening. I try to sync as often as possible. I work during the day and it does not make the whole night!!!!! Help me please.
05-25-2020 08:24
05-25-2020 08:24
The same happened to mine. The battery gives problems with little more than 1 year. I saw a tutorial on Youtube on how to replace the battery, I bought once and exchanged it.
The Fitbit Alta HR battery is at 45 mAh 3.8 V 2mm x 10mm x 20mm. Maybe you want to try to do the same. Good Luck!
Best Answer05-26-2020 04:37
05-26-2020 04:37
thank you
I may try to do so at have my technical inclined 21 year do so. Lol I am not so much confident with electronics. Lol
Best Answer05-27-2020 12:56
05-27-2020 12:56
Mine battery also just suddenly started draining very quickly and I cannot make it more than 7 hours without a charge. I have had the alta for 15 months and have been told that they wont do anything because the warranty has expired. Interesting that the batteries are failing just after the warranty is up.
Best Answer05-30-2020 17:03
05-30-2020 17:03
My Fitbit also started doing the same since a few days ago. Battery lasts hardly a day, and for the first time it died in the middle of my workout Yesterday. Super upset. Mine is almost 3 years old, and I haven’t had any issues until now. Has it really come to the end of its lifetime , or can we replace the battery?
Best Answer06-01-2020 06:35
06-01-2020 06:35
