09-04-2020 19:47
09-04-2020 19:47
I rarely use my fitbit these days because it stays charged for less than 6 hours on a full charge. Does anyone have any suggestions. It is about 1/2 - 2 years old but I cannot afford a new one. appreciate any suggestions to longer battery use.
Best Answer09-10-2020 21:30
09-10-2020 21:30
Hi @Lisakary
make sure your Fitbit is fully charging before you take it off the charger.
Turn off the silent alarms, Notifications, Reminders to move, & turn off quick view
you can find all these settings under Account - Alta
Also make sure your charging contacts are clean to ensure a proper charge.
Don’t get it wet. And don’t charge it till its battery is drained fully. That’s what I do to maximize the battery life.
Hope this helps! Let us know how this goes.
Best Answer09-10-2020 22:14
09-10-2020 22:14
Best Answer09-11-2020 19:24 - edited 09-11-2020 19:39
(deleted)
Best Answer09-12-2020 07:27
09-12-2020 07:27
Hopefully that helps.
let us know if there was any improvement.
