05-15-2021 04:25
05-15-2021 04:25
How do I get the symbol to show on my tracker without plugging it in to charge
05-16-2021 00:33
05-16-2021 00:33
I found this in the manual:
"If your battery is low, when you wake up your Alta HR you’ll see low battery icon
after a few seconds. If you see a critical battery icon you’ll be unable to flip through
your stats until you charge your tracker. Your tracker continues to track your
activity until your battery runs out. Note that heart rate tracking will stop when
your battery level is at approximately 5%.
You can check your battery level at any time on the battery screen on your tracker
or on your Fitbit dashboard. You must turn on the battery screen in the Fitbit app, it
is not on your tracker by default. "
05-16-2021 00:33
05-16-2021 00:33
