01-07-2022
19:43
11:29
01-07-2022
19:43
11:29
I'm having a hard time finding the right charger for my Fitbit AltaHR. I lost my charger that came with the Fitbit AltaHR. Seems it's an older model and no one has the right charger with the three (3) charger spots. The ones I found on Amazon have two (2) charger spots that won't work. Any help on where to buy a new charger?
01-07-2022 20:55
01-07-2022 20:55
Hi @Junebug5000 the Alta HR was retired in 2019 and has been replaced by two different styles. Has it been long since you used it? Sometimes the battery is left dead for a long time and it doesn't revive. Since it's no longer sold, you'll have to just try an off brand charger for it. With Amazon, just be sure it's one of their Prime sellers and they take returns in case it doesn't work for you.
01-08-2022 06:51
01-08-2022 06:51
01-08-2022 07:36
01-08-2022 07:36
@Junebug5000 the issue of how many prongs has been talked about on the forums. There aren't as many prongs needed as it might seem. If it was me, I'd chance getting one of the higher reviewed charging units. Meanwhile, use MobleTrack to keep your steps being counted on your Fitbit account. click to learn more
01-14-2022 12:39
01-14-2022 12:39
Just FYI -- I just received the 2 prong charger from Amazon. I have a 3 prong old AltaHR -- the 2 prong charger worked! Just to let other AltaHR users with 3 prongs know that it did work. Be sure to order the charger for the AltaHR. Thanks for your help!
01-14-2022 17:10
01-14-2022 17:10
Wonderful news @Junebug5000 and thanks for letting us know. Glad you tried it, because you may have helped other Fitbit users with a similar problem.
04-23-2023 05:48
04-23-2023 05:48
I have a similar problem in that I can’t find a charger to fit my old Fitbit Alta HR which has the 3 buttons. Just wondering which 2 pronged charger worked for you so I can purchase from the same site? Thanks!
Best Answer04-23-2023 10:37 - edited 04-23-2023 10:45
Hello @Juliemol3000 and welcome to the Community. The Alta HR manual shows a two prong charger on page 6. I never owned an Alta HR, so I don't know if it came with a three prong cable or not. The earlier post might not help. It is over a year old and that brand might not be available. I can say that there are Alta HR chargers available on Amazon. Look for recent reviews from Verified Purchases to see if that brand works.
Make sure it is for the Alta HR, not the Alta. The chargers are different. The only issue I know of is that many third party models don't have the restart button that is part of the charging cable. You need the button to restart an Alta HR. Then again, the Alta HR is an older model tracker and users are experiencing end-of-life battery issues.
FWIW, my Charge 2, 3, 4, 5, and Luxe all have three charging contacts on the back of the device. But every charger has only two prongs.
Laurie | Maryland
Best Answer04-23-2023 11:33
04-23-2023 11:33
Best Answer04-23-2023 12:06
04-23-2023 12:43
04-23-2023 12:43
Junebug5000,
Have you looked for Alta HR chargers on EBay? They will be used but you might be able to find a charger there.
I've found used Alta HR (with chargers) listed on EBay.
Amazon usually do not sell used items of these types (Fitbit) so you'll have a harder time finding it on EBay.
Best Answer04-23-2023 13:11
04-23-2023 13:11
